What oil to use in Bolens Tiller
6 replies to this topic
#1 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 25, 2015 - 01:17 PM
I want to drain the old oil from the gear box out of the tiller (& the mowing deck). Can I use EP90 oil? If not what oil is recommended.
Thanks
  • MyBolens1053 said thank you
#2 chieffan OFFLINE
  • 16594 Thanks
  • 9088 posts
Posted January 25, 2015 - 01:48 PM
I use 80/90 gear oil.  Been told not to use any synthetic oil as that oil works on the bronze bearings & bushing inside the gear cases.  I would think you EP90 would be about the same as 80/90 Gear Oil.
  • Bolens800uk said thank you
#3 grand OFFLINE
grand
  • 2309 Thanks
  • 2074 posts
Posted January 25, 2015 - 04:45 PM
We also use 80/90 gear oil. When I did a web search for EP90 oil one of the results was AutoZone, but when I clicked on the link I realized I wasn't in the states anymore. Apparently this was a link to their overseas stores. But their site did say that EP90 oil is for use in all manual gear boxes, so it sounds like you would be fine using that oil.
#4 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 25, 2015 - 05:08 PM
Thanks chaps; I thought that was the case but it is always good to get confirmation.
#5 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted January 25, 2015 - 05:27 PM
Thanks
EP90 for vintage, veteran and classic cars in the UK and across the world. GL4 formula is what you want.
http://www.demon-tweeks.co.uk/performance/gear-oil/castrol-classic-ep90-gear-oil
Avoid GL-5 formula if you can. Different additives that attack copper and bronze, causing pitting over time.
Edited by MyBolens1053, January 25, 2015 - 05:35 PM.
#6 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 25, 2015 - 06:07 PM
Thanks.
I am going to check the EP90 I got in the garage to see off it's synthetic. I don't think it is but if so I will buy an appropriate oil.
#7 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted January 25, 2015 - 10:40 PM
I'm not sure that I'd even trust GL4 spec oil.
GL1 is still available, and it's definitely compatible with any 'yellow metal' components that might be in a gearcase.
  • Bolens800uk and Doug E. have said thanks
