Holy cow! It worked! Pics
18 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 24, 2015 - 04:53 PM
We built a garage this past summer and, now that I have a smooth concrete floor, I decided to try something.  I usually take the FEL off the Massey in order to mount the snow blade for the winter.  I just actually did that today and here it is, the last part of January!  Anyway, I kept trying to decided where best to put the FEL for the remainer of the winter.  It had to be out of the way but in a place where I could install it again pretty easily when I'm ready.  Then it hit me, WHEELS!  Why not put the thing on wheels so I can move it around the garage?  I had a furniture dolly and decided to order a couple more little three wheel dollys for the stands.  I wasn't sure what to expect but, as you can see from the pics, it worked great!  I had it where you see it in the pic while I mounted the blade.  Once I decided where the tractor was going to park, I pushed the FEL over against the backwall for now.  I love it when a plan comes together!
  • NUTNDUN, olcowhand, Gtractor and 18 others have said thanks
#2 boyscout862 ONLINE
  • 13,554 Thanks
  • 9,430 posts
Posted January 24, 2015 - 04:59 PM
Very nice. Why not just take the bucket off and put a plow on the loader. There have been many times when I've needed to push the piles to 9'+ with my FEL just to get the snow out of the way. Congratulations on the new garage too. Good Luck, Rick
  • David Brown and Coventry Plumber have said thanks
#3 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 24, 2015 - 05:04 PM
I almost got the plow that mounts on the loader arms but the whole rig became ridiculously long and I didn't have the place to put it under roof like that.  This works for me.  Here's a picture of the rig with the blade on.  Love power angle!  Pic was taken last year before garage.  You can see the track for the door on the right.  This is why I needed a shorter machine.
Edited by David Brown, January 24, 2015 - 05:05 PM.
  • Gtractor, wvbuzzmaster, IamSherwood and 2 others have said thanks
#4 KC9KAS OFFLINE
KC9KAS
  • 5,468 Thanks
  • 4,723 posts
Posted January 24, 2015 - 05:05 PM
Great idea!
Glad to see you used a ratchet strap to keep the dollie under the bucket.
  • tinbender7, David Brown and Coventry Plumber have said thanks
#5 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted January 24, 2015 - 05:11 PM
That worked like a charm!  That's one of the things I'm really looking forward to whenever I finally finish our new shop.....smooth floors!  It's gonna be nice being able to move heavy objects on floor jacks easily.  Our old shop's floor is full of irregularities, pits, ridges, etc, and makes for a lot of aggravation.  Do those furniture dollies come in 10,000lb versions?  :smilewink:
  • GTTinkerer, HDWildBill, David Brown and 2 others have said thanks
#6 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 24, 2015 - 05:17 PM
Kinda doubt it.  These ones are good for 300 lbs I believe.  Pefect for this application because all the weight in on the bucket end.  I was worried about the small wheels but they seem to work well.
Edited by David Brown, January 24, 2015 - 05:17 PM.
#7 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 10,879 Thanks
  • 6,359 posts
Posted January 24, 2015 - 06:14 PM
That is pretty slick!
  • David Brown said thank you
#8 boyscout862 ONLINE
  • 13,554 Thanks
  • 9,430 posts
Posted January 24, 2015 - 06:30 PM
That tractor is too pretty to take out in bad weather. You need to get an ugly tractor to use in ugly weather. Good Luck, Rick
  • David Brown and Rock farmer have said thanks
#9 Cvans ONLINE
  • 7,296 Thanks
  • 6,382 posts
Posted January 24, 2015 - 06:39 PM
Another thing that works well are those dollies your can buy for moving snowmobiles. They have four casters and are rated at 1500 lbs. I've had good success with them.
Edited by Cvans, January 24, 2015 - 06:41 PM.
  • David Brown, superaben and oldedeeres have said thanks
#10 MH81 OFFLINE
  • 29,979 Thanks
Posted January 24, 2015 - 07:38 PM
Jeff, that's great. I think that's a lot of thinking outside the box. :thumbs:
#11 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 24, 2015 - 07:41 PM
I looked at those but my budget wouldn't allow it.  The ones I got work well for this because they are low in the center so the posts sit down in and don't move or try to come off.  I'm really pleased with how this works.
  • NUTNDUN and Cvans have said thanks
#12 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 24, 2015 - 07:43 PM
But snow is pretty.  That pic was taken when I only had a couple of hours on it.  It doesn't look quite as good now.  You buy them to work, you know?
  • NUTNDUN, MH81, boyscout862 and 1 other said thanks
#13 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted January 24, 2015 - 10:09 PM
I would like to see some more pics of the Massey. Looks like the front end loader removed from the tractor easier than the old Johnson loader like I have on my Massey 1655. Being able to wheel it around on the skates is an awesome idea. :thumbs:
#14 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 24, 2015 - 10:21 PM
I don't actually have too many pictures of the Massey.  Guess I'll have to work on that.  Maybe some action shotd if we get this snow that's supposedly coming in.
  • NUTNDUN said thank you
#15 NUTNDUN OFFLINE
  • 10,352 Thanks
Posted January 24, 2015 - 10:41 PM
You should know by now pics are a much requested aspect of the site. :D
I would definitely like to see more pics of the tractor and see how it is setup. Action shots would be wonderful as well.
  • Cvans, David Brown and propane1 have said thanks
