Eletric fuel pump
kohler m18
9 replies to this topic
#1 shorty ONLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted January 23, 2015 - 10:55 PM
I have this Gravely with a Kohler M18 in it. The fuel pump is very weak with both check valves leaking. So I am thinking of putting on an electric pump.
Now the question is, Do you let the mechanical pump on? Pump the fuel through the old pump? Or take the mechanical pump off and put a plate over the hole.
How big of an electric pump will I need?
#2 gopher OFFLINE
gopher
  • 763 Thanks
  • 757 posts
Posted January 23, 2015 - 11:04 PM
Go to Kirk Engines lots of Kohler information and kits. In any case do not use high pressure auto pump.
  • shorty and boyscout862 have said thanks
#3 cpg OFFLINE
cpg
  • 251 Thanks
  • 151 posts
Posted January 23, 2015 - 11:10 PM
We had an old Bolens with a rear tank that didn't feed fuel very well and the vacuum pump died so instead we just got a universal 12v electric pump from an auto supply store. At the input to carb we just put a T and a return line back to the tank. That way once the carb filled it wouldn't just flood since the automotive pump will put out plenty of flow for a GT carb. It worked really well and from that point it became our ditch mowing tractor because it would always feed fuel really well on hills even without a full tank.
Just make sure if you do use an automotive pump to be sure it is for carbureted vehicles as they only run a few psi. If you try to use one designed for fuel injection you will end up having issues.
Edited by cpg, January 23, 2015 - 11:12 PM.
  • tinbender7, shorty and boyscout862 have said thanks
#4 Bill 76 ONLINE
Bill 76
  • 1,930 Thanks
  • 1,190 posts
Posted January 24, 2015 - 04:54 AM
If its a mechanical pump and it not leaking oil I would leave it on I also would not run your new lines through it in case it starts leaking gas into the engine.
  • tinbender7 and shorty have said thanks
#5 shorty ONLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted January 24, 2015 - 04:58 AM
I hope to pick one up today. Got snow to move and another storm on the way.
  • tinbender7 said thank you
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted January 24, 2015 - 06:33 AM
Napa 6101051 (plastic) or Napa 6101075 (metal) will work fine. They run 2-4 psi.
  • Bruce Dorsi, gopher and shorty have said thanks
#7 boyscout862 ONLINE
  • 12,849 Thanks
  • 9,171 posts
Posted January 24, 2015 - 08:35 AM
The mechanical pumps can usually be rebuilt. Someone in the Boston area is selling replacements pumps and kits. Good Luck, Rick
  • shorty said thank you
#8 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted January 24, 2015 - 10:03 AM
I always switch to electric.  My reason is after a tractor sits a while, the carb fuel can evaporate.  With mechanical or vacuum fuel pumps, it can take a bit of cranking over before fuel arrives to the carb.....more wear on starter system, and can run battery down.  With electric pumps, turn the key to on a few seconds before cranking, and she'll light right off if all else is right.
  • limebuzz, wvbuzzmaster, gopher and 3 others have said thanks
#9 shorty ONLINE
shorty
  • 5,481 Thanks
  • 5,261 posts
Posted January 24, 2015 - 08:11 PM
I was kind of thinking along that line too. It can easily go over a month that I won't use it. Then it is a pain to get started.
#10 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,802 posts
Posted January 24, 2015 - 11:12 PM
A few years ago, I did just what you're doing with my M18. I just bypassed the stock pump and left it in place as pulling it would have required pulling the engine to get the shrouding off. If it's not leaking oil out of it there's no reason to pull it.
Also tagged with one or more of these keywords: kohler, m18
