Regulator Question?
50 replies to this topic
#31 DH1 ONLINE
DH1
    Electric Tractors
  • 5,243 Thanks
  • 5,552 posts
Posted January 26, 2015 - 06:02 PM
Glad you got it working for ya.
#32 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted January 26, 2015 - 06:29 PM
Good deal Kenny!  I think you're good to go on the charging now.
Now to get this spitting out the exhaust & intake to clear up. The engine sounds good at a fast idle, so the carb may be part of the issue. I'm hoping the Seafoam & MMO will help out some.
I'll probably revert back to the tiller thread from here!
  • propane1 said thank you
#33 propane1 ONLINE
propane1
  • 8,479 Thanks
  • 4,040 posts
Posted January 26, 2015 - 07:07 PM
A little transmission oil in the gas , and a little more in the oil may clean up your troubles. Governor on my ferguson tractor was not working, put transmission oil in base oil , cleaned things up and is now working. Also stuck exhaust valve in Mf 14 was fixed by transmission oil. Noel
  • limebuzz, KennyP and Sawdust have said thanks
#34 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted January 26, 2015 - 07:31 PM
That's about what MMO is! Tranny fluid does work real good, though!
#35 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted January 27, 2015 - 06:41 AM
As I was checking connections, I found the Electric Lift switch is NOT a momentary switch. This I did not like. So I Googled DPDT Momentary switch and found this on Amazon:
It'll be here early next week. Actuator should show here Thursday, probably late afternoon. I can use the old switch to figure out the wiring for it.
  • olcowhand, Sawdust and propane1 have said thanks
#36 propane1 ONLINE
propane1
  • 8,479 Thanks
  • 4,040 posts
Posted January 27, 2015 - 08:13 AM
Nice looking switch. Noel
#37 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted January 27, 2015 - 08:22 AM
I'll post a review of it when I get it.
#38 Sawdust OFFLINE
Sawdust
  • 5,563 Thanks
  • 3,335 posts
Posted January 27, 2015 - 09:47 AM
Glad everything is working out. It's good to read & learn of the many different charging systems. Sooner or later we all have to deal with them.
  • KennyP and propane1 have said thanks
#39 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted January 27, 2015 - 10:12 AM
Me too, Jim! These type of threads help us all learn about different things. When I started the thread, I was sure this had a 15 amp charging system. I glad I pulled the flywheel and found out for sure what it had. Of course, the info was there all along in the parts manual. I just didn't take the time to figure it out.
I think the old regulator may still work. I'll get a pic of the back side later, but there looks to be a 'cold' solder joint back there. Ohm meter does not show continuity there.
  • TomLGT195 said thank you
#40 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted January 27, 2015 - 07:14 PM
Here's a pic of the back of the regulator. Upper right is a not so good looking solder joint. Just below that and a bit left is the one I could not get continuity through the solder and prong. I re did those two spots. Now to hook it up and see if it works. If not, nothing lost!
I did another test on the system. Wound the engine up and turned the PTO on. Got a 14.4 volt reading. So it is charging well. After turning the PTO off, it went back to 14 volts. Hopefully this will work okay with the actuator.
#41 Alc ONLINE
  • 6,750 Thanks
  • 7,399 posts
Posted January 28, 2015 - 06:21 AM
Kenny glad to hear you got to the bottom of the charging problems and soldering the joints saved $$ , I'm still scratching my head on how the 10 amp stators can make 20 volts ac to 14.5 dc :(   I even tried looking for info but the 10 amp didn't have much at all . Maybe some of the sharp electrical members would be able to explain it to me , Al
#42 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted January 28, 2015 - 08:41 AM
I don't understand it Al. I do have the 20 amp regulator installed right now, not the 10 amp I repaired. I may test it today to see if it works now. I think the AC volts have increased some since I cleaned things out, I'll check that also.
#43 Alc ONLINE
  • 6,750 Thanks
  • 7,399 posts
Posted January 28, 2015 - 08:49 AM
Kenny even if it's more then 20 volts the trouble shooting sheet you posted calls for " over 20 volts ac "  I'm confused , though it doesn't take too much lol
#44 KennyP ONLINE
  • 37,511 Thanks
  • 45,513 posts
Posted January 28, 2015 - 09:02 AM
And on that sheet in Test D max voltage is 14.7 Volts for the 10 Amp system. I don't understand either!
On another note, when I turned the PTO on, the light in the dash worked! That surprised me!
#45 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted January 28, 2015 - 09:44 AM
The voltage regualtor will usually put put out a max of 14.5-.7 Volts DC on most systems. They are also limited on amps as to prevent overloading the wiring and causing a fire.
The 20+ volts you all are talking about is produced as AC across the two leads coming from stator. If you put a meter on both those leads,turn to AC, you need to have 20+ volts across those 2. Once it goes into regulator, it gets converted to DC and comes out at the 14 or so max to charge battery.
My system is a 20 amp on my Sears, I have burnt up more than 1 regulator as I was trying to use my high draw head lights and winch at the same time. With lights on and the first draw from winch, I pull more than 20 amps so I eventually over heat and burn up regulator. Looking into LED lights to help that.
Edited by TAHOE, January 28, 2015 - 09:46 AM.
