What is the model number and serial number on your sunstrand pump?
12 replies to this topic
#1 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,448 Thanks
  • 3,361 posts
Posted January 22, 2015 - 05:55 PM
Working on a project and looking for feedback. Bush hog used the sunstrand pump on the HD-12 and JB tractors. I know the sundstrand pump was used on the JD 140 and some of the Gilson models. Looking to see what model pump was used on which tractors. Please post your tractor model, sunstrand model and sunstrand serial number. Just looking for similarities. Maybe cut and paste each previous post and add yours to it???? Or just post your info. Either way works.
Thanks Scott
Model 90 201  serial FA 5223  spare
Model HT90-2067  serial 01-HB 102834 spare
Model 90-2067 serial KA 0076 – on a JB
Model HT90-2067 serial 01-HB-0272  spare
Model 90-2067  serial 01- JA  28754- on a JB
Model 90-2067  serial – need to clean up to read- on the early HD-12
Edited by sacsr, January 23, 2015 - 06:32 PM.
  • NUTNDUN and DH1 have said thanks
#2 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted January 22, 2015 - 06:18 PM
Scott,
Just one question. Is the tag easily viewed for the Sundstand on the Bush Hogs?
#3 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,448 Thanks
  • 3,361 posts
Posted January 22, 2015 - 06:21 PM
Yes, it is directly opposite the shaft on the top of the pump. I have been cleaning it off and using my camera to take a picture of it, since it is on the bottom side of the pump. Probably could slide underneath and see it better, but most of mine are in a shed with a dirt.
Edited by sacsr, January 22, 2015 - 06:27 PM.
#4 olcowhand ONLINE
  • 40,335 Thanks
  • 31,169 posts
Posted January 22, 2015 - 06:23 PM
Scott, I'll look as soon as I get time & post results.
  • sacsr said thank you
#5 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted January 23, 2015 - 10:35 AM
Pennsylvania Meteors use Sundstrand pumps.  Unfortunately, the tag faces the engine and is inaccessible.  I have an extra one in the shed so I'll see if I can get at it this weekend.
#6 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted January 23, 2015 - 01:26 PM
I was home for lunch so I got a picture of the tag on my spare in the shed. This is off a later ('67/‘68? - '69) 1012 Meteor.
Hydrogear model:90-2027 serial:FB-01166
Mfg by Sundstrand Hydro-Transmission
#7 shorty ONLINE
shorty
  • 5,274 Thanks
  • 5,161 posts
Posted January 23, 2015 - 10:35 PM
Ariens S-16 model 931010 approx 1975-76
  Sunstrand model 90-1075LH  serial 03-RL 12561
  Tag is on the front between shaft and filter.
Gravely 18H          unknown year
  Sunstrand model 90-1223CCW serial 06-87-12 19825
Edited by shorty, January 23, 2015 - 10:37 PM.
#8 TUDOR OFFLINE
TUDOR
  • 544 Thanks
  • 497 posts
Posted January 24, 2015 - 07:08 AM
There are 2 types of Sundstrand Series 15 hydros used in GT's, the inline type found in Massey Ferguson and other brands, and the U type found in most JD tractors using Sundstrands, as well as other brands. The JD400 is the exception with an inline type. All bear the model number starting 90-. The rest of the digits refer to specific changes to the base design and all can be switched from one to another of the same type, and in some cases between the types as well, as these changes are parts or rotation direction, or in the case of the U-type, motor swash plate angle which is part of the casting.
If you're looking to replace an existing unit, depending on what the reason is, buy any of the same type of hydro and swap out the necessary parts from the old one. The input shaft is the one most likely to cause headaches. There are at least 2 different shafts for each type. If your input shaft is toast, you want a replacement with the same shaft or be prepared to modify the drive shaft.
There is also a split hydro with a separate pump section and motor section. The pump section can be used to replace the pump section of an inline hydro by removing the rear plate. The internals of the motor section can be used, but the castings are for a stand alone motor and will not work with the final drives of most GT's.
  • DH1, sacsr and shorty have said thanks
#9 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,448 Thanks
  • 3,361 posts
Posted January 24, 2015 - 07:16 AM
Great info!! Thanks!! I have extras of these pumps and trying to figure out what options I have in selling some. I figured there had to be more than 1 gt these units would fit. I appreciate your expertise on this matter!! Good stuff!!
Any idea what the difference between a HT90 and a 90?? Any where to find the info on how to decode these numbers?
Again thanks!
#10 KennyP OFFLINE
  • 37,398 Thanks
  • 45,448 posts
Posted January 24, 2015 - 07:28 AM
The Toro Grounds Master 322D uses a Sundstrand 15 inline, but it is in winter storage right now.
#11 sacsr OFFLINE
sacsr
    Bush Hog Addict
  • 3,448 Thanks
  • 3,361 posts
Posted January 24, 2015 - 07:42 AM
Just to add more info to the thread. I found this on another GT site googling Sundstrand 15. This link is to a WH site thread. If this conflicts with the rules of GTtalk, just delete this post. But these guys did some research on these pumps in their WH and it provides some good info in the thread. http://www.wheelhors...p-model-number/   The 90 designation is where the pump and motor are designed as a unit. WH used 90-1136 or 90-1137 or 90-1140.
  • TUDOR and shorty have said thanks
#12 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,546 posts
Posted January 24, 2015 - 11:56 AM
According to the Operators Manual I have for Massey MF14 and MF16 tractors, dated 1/75 it says >
Sunstrand Inline "HT-90-1122"
Edited by DH1, January 24, 2015 - 11:56 AM.
#13 TUDOR OFFLINE
TUDOR
  • 544 Thanks
  • 497 posts
Posted January 25, 2015 - 02:44 AM
I saw a breakdown of the model numbers in a thread on MTF several years ago, but didn't save it. :wallbanging:  Most of my info is based on a thorough reading of the  Saur Danfoss Series 15/70 Technical Information Manual, the link for which has since been broken.
Sorry!
