Dual wheel set ups
18 replies to this topic
    Make Stuff Up
  • 4,422 Thanks
  • 2,524 posts
Posted January 21, 2015 - 08:50 AM
I used a set of front wheel weights off of a Minneapolis Moline (full sized tractor) for spacers. It worked really well and gave the old sears good weight. They were the right size to fit right in the lip of the wheel.
Now I have duel wheels so I just use them as weights.
  • JDBrian and T Guiles have said thanks
#17 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted January 21, 2015 - 11:01 AM
So far I have learned that their is a few way to do this, you have a hub type that mounts to the center wheel bolts on each rim. then you have a spacer ring that fits in the groove on the outer edge between the rims. what's the better set up?
#18 OldBuzzard ONLINE
  • 7,044 Thanks
  • 4,796 posts
Posted January 21, 2015 - 04:09 PM
I think that I'd be more inclined to use the hub adapters instead of the spacer type
Bolens offered a dual wheel kit for the large frames that just use deep dished wheels that bolted directly to the hub.
here's what they look like when mounted on a 1250
  • T Guiles said thank you
#19 drbish ONLINE
  • 1,570 Thanks
  • 1,369 posts
Posted January 21, 2015 - 06:15 PM
Here are some Wheel Horse ones.
  • OldBuzzard and T Guiles have said thanks
