Dual wheel set ups
18 replies to this topic
#1 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted January 20, 2015 - 07:27 PM
I watched a video on youtube where the dude put 2 drive tires on the rear of a sears ss16, he had a ring that was placed between the rims. I assume it was to evenly spread the weight from the outside rim to the inner and keep the rims inline. Anybody have pic's of the ring. I think I want to put duel wheels on something I own and don't think it would be too hard to make. Thanks Todd
  • Coventry Plumber said thank you
#2 Tomwendt OFFLINE
Tomwendt
  • 129 Thanks
  • 142 posts
Posted January 20, 2015 - 08:14 PM
i bought the kit on ebay for about 50.00.works great.tough to make without a metal roller.
  • T Guiles said thank you
#3 Cat385B ONLINE
    Therapy CAT
  • 12,627 Thanks
  • 9,344 posts
Posted January 20, 2015 - 08:24 PM
It's to line up the rims. That way all you need is long j bolts to put on the duals, nothing special other than the spacer ring and long j bolts are necessary. They got fancy here and used clamps. Either way, band duals:
#4 Justin2655 OFFLINE
Justin2655
  • 204 Thanks
  • 148 posts
Posted January 20, 2015 - 08:44 PM
I had spacer rings made at my local machine shop and bolt the two tires together just oike the big tractors bassically instead of doing hub duals. They work and look pretty good
#5 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted January 20, 2015 - 09:22 PM
Thank's. I am going to get some measurements and talk to a friend about making them. I have seen people just bolt the rims together with out the spacer rings and it looked and worked like crap.
#6 rustyoldjunk ONLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,518 Thanks
  • 1,281 posts
Posted January 20, 2015 - 10:01 PM
I have heard of using large heavy duty pvc pipe also but I have never tried. Most people use long carriage bolts but J bolts will work too.
#7 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted January 20, 2015 - 10:10 PM
#8 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted January 20, 2015 - 10:12 PM
How can they do that and keep the wheels apart? The wheels in a dual wheel set up can't (or shouldn't) touch so you would need some sort of a spacer.
#9 dodge trucker ONLINE
dodge trucker
  • 1,623 Thanks
  • 2,130 posts
Posted January 20, 2015 - 10:46 PM
not as critical in a low speed non highway deal like a garden tractor.
#10 rustyoldjunk ONLINE
rustyoldjunk
  • 2,518 Thanks
  • 1,281 posts
Posted January 20, 2015 - 11:06 PM
You cut the pipe to the same length as you would metal spacers.
#11 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted January 20, 2015 - 11:18 PM
The one I saw the outside tire moved a up when the tires were not on a level surface. Maybe they weren't tightened enough but I'm sure over time this would cause wear on the rims.
  • rustyoldjunk said thank you
#12 David Brown OFFLINE
David Brown
  • 4,508 Thanks
  • 2,424 posts
Posted January 21, 2015 - 05:25 AM
Maybe, but low speed or high, the purpose is to protect the sidewall of the tires which can wear at any speed.  At least, that's what I was always told.
#13 Justin2655 OFFLINE
Justin2655
  • 204 Thanks
  • 148 posts
Posted January 21, 2015 - 06:55 AM
I beleive I made mine inch and a half ring spacer if I remember right
#14 KennyP ONLINE
  • 32,147 Thanks
  • 41,982 posts
Posted January 21, 2015 - 07:16 AM
Maybe there is some into in this thread.
#15 BNK OFFLINE
BNK
  • 1,054 Thanks
  • 471 posts
Posted January 21, 2015 - 08:07 AM
Miller tire offers those dual spacer kits. I used a set on a 108 Cub Cadet with a Haban sickle Mo. The kit worked for me. I also cut off 2 axle shaft plates from worn axles and bolted them to the inside outer rims to give the look of real dual set up.
  • CRFarnsworth and T Guiles have said thanks
