Toro Rototiller Tecumseh H35 Engine Not Starting
20 replies to this topic
#16 Alc ONLINE
  • 6,884 Thanks
  • 7,459 posts
Posted January 21, 2015 - 06:34 AM
  Always like reading this types of threads you can learn so much from the members here.   Hope you get to the bottom of your starting problems ,
#17 bh115577 OFFLINE
bh115577
  • 443 Thanks
  • 240 posts
Posted January 21, 2015 - 07:13 AM
This manual covers the H35. Might be something in there to help.
Attached File  Tecumseh.pdf   2.49MB   137 downloads
Edited by bh115577, January 21, 2015 - 07:13 AM.
  • Alc and Bruce Dorsi have said thanks
#18 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted January 25, 2015 - 07:41 PM
So here is an update. I reconfigured the ignition timing per the instructions Ben attached in his post. (Thank you btw).
Still have a no start condition.
Here is what I know:
1. Ignition Timing now correct
2. Point Gap Correct
3. Getting Spark (confirmed via spark tester)
4. Valve Lash within spec
5. Valves sealing properly
6. Good Compression.
7. Flywheel Key in good condition
What is going on!?
I spray Carb Cleaner directly into spark plug hole, and it still will not fire.
#19 MH81 OFFLINE
Posted January 25, 2015 - 10:17 PM
Wow, sounds like a conundrum... if I were you, i would Grab another plug. One that does not have a C in the name would be my suggestion.
#20 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted January 26, 2015 - 04:00 AM
I agree with Alan - Try a NEW sparkplug.  ....Sometimes new plugs are not good.
In one of the earlier posts it mentions an orange spark.  .....A STRONG spark is usually blue in color, and can jump a 3/16" gap (to ground) with no problem.
Sometimes, a spark will show on a tester, but it may not be strong enough to fire under compression.  ....Place a few drops (don't over-do it!) of gas on the top of the shroud.  ...Lay the sparkplug next to the gas (plug wire connected to plug), and see if the spark will ignite the gas.  ....If not, you have bad fuel or weak ignition.
You can also try hand-choking the engine by sealing the carb intake with your hand, as you crank the engine.  .....You should feel a firm suction against your hand, and if done a few times, and the engine does not start, the sparkplug should be wet with unburnt fuel.   .....If that is the case, you have weak ignition, bad sparkplug, or bad fuel.
If hand-choking does not cause fuel to be drawn into the cylinder, you have a carb problem, fuel flow to the carb problem, or a compression problem.
Someone mentioned the possibility of a clogged exhaust.  ....This can indeed prevent an engine from running.
Also, when you had the flywheel off, did you check the "pull" of the magnet with a screwdriver?  ....Weak magnets are not common, but can occur and leave someone scratching their head.
There is always an answer to these problems.  .....Sometimes the answer is obvious, while other times it is not.  .....It is much harder to diagnose problems over the 'net, than in person.
Please let us know what you find!
#21 olddog OFFLINE
olddog
  • 1 posts
Posted April 03, 2015 - 03:39 PM
Hi,  I've been struggling with my Troy built Jr engine, Tecumseh H35.  Last fall the engine stopped and I have not been able to start it since.  After checking all the usual things, I decided to completely strip the engine, just so see if there something unusual.  Nothing obvious at firs, but as the re-assembly progressed, I found that the valve timing is off about 90 degrees.  I take it the timing gear on the crankshaft has slipped.  I'm not sure how to fix this, but I assume it's a press fit gear.
I've never heard of this, and I'm sure I have the timing marks meshing correctly.
Regards,
Olddog
