John Deere 210
5 replies to this topic
#1 cubcadet123 OFFLINE
cubcadet123
  • 5 Thanks
  • 5 posts
Posted January 17, 2015 - 05:29 PM
Anyone know where I can buy the seals for a peerless 2300 out of a John Deere 210. I need both axle seals, Input Shaft Seal, and Brake Shaft Seal. Also I have a question about the outer axle. Is this a seal/bearing together or is it just a bearing that must be greased. A friend of mine told me there was someone on this site that sold a seal kit for these. Id rather buy them off of here than John Deere.
  • A.C.T. and superspeedex have said thanks
#2 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 17, 2015 - 05:37 PM
You need this.
http://gardentractor... rebuild kits
  • boyscout862 and superaben have said thanks
#3 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted January 17, 2015 - 08:03 PM
Yep, Ben is who you need to talk to.
  • superaben said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted January 17, 2015 - 10:53 PM
I am the Ben that sells the seal kit.  It goes for $49 and has all the seals and gaskets you will need to go through your transmission.
The bearings are outside of the main seals seals on the 2300.  They are ball bearings with a seal built into them.  I can't remember if there is a grease point there or not?  Somehow I don't think there is, but I might be wrong.
Ben W.
  • superspeedex said thank you
#5 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 18, 2015 - 12:55 AM
The axle tube theres a sealed bearing at the end but the seal is inboard like against the center cases
#6 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted January 18, 2015 - 05:12 PM
you can download a peerless transaxle manual from the manual section on site
look for Tecumseh/Peerless 2300 Transmission Repair in the transmission section
there are other manual there that will help
