Charging system on Briggs & Stratton 16Hp opposing twin
1 reply to this topic
#1 Tinkerer OFFLINE
Tinkerer
  • 18 Thanks
  • 200 posts
Posted March 04, 2011 - 08:36 PM
When I am running my Bolens 1600H which has a B & S 16 Hp opposing twin I notice the amp gauge shows I am charging for a little while and then it goes to zero and then a little while later it starts charging again. This cycle repeats itself the entire time I am running the tractor. I made sure the voltage regulator is well grounded but that hasn't changed anything. Has anyone had this happen to any of there motors? The engine is a 1987. I think it is the voltage regulator but being they are expensive I don't want to just go and buy one until I am sure that the regulator is the problem. Thanks in advance for any input.
#2 Big John OFFLINE
Big John
  • 24 Thanks
  • 96 posts
Posted March 06, 2011 - 05:19 PM
The only thing I can offer is to check for loose or corroded connections, especially the battery posts.
Otherwise it probably is the regulator.
