K341 timing mark
which one?
4 replies to this topic
#1 dadscub OFFLINE
dadscub
  • 14 Thanks
  • 14 posts
Posted January 14, 2015 - 09:39 PM
mine dont have balance gears and there is two marks on crank just want to make sure
#2 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted January 14, 2015 - 10:41 PM
Check the manuals section here and download the appropriate manual. It will have the exact info on which mark is for the camshaft and crankshaft timing.
  • boyscout862, superaben and dadscub have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
You are trying to time the crank to the cam.
The primary mark on the crankshaft is the "dash" on the land next to the gear.  The secondary mark (only used for the balance gear setup) is on the counter throw casting.  You are aligning the primary mark to the camshaft mark.
Without the balance gears, it is a piece of cake.  You are aligning the two marks (one on the cam, one on the crank) together and then all you need to do is button up the engine.
Ben W.
  • Alc, boyscout862 and dadscub have said thanks
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 14, 2015 - 10:42 PM
He would need the K series service manual, very thorough and very useful!
Ben W.
  • dadscub said thank you
#5 KennyP ONLINE
  • 40,110 Thanks
  • 46,761 posts
Posted January 15, 2015 - 05:15 AM
Here's the Kohler K91 to K341 Service Manual!
  • FilledTires said thank you
