How many Ponies?
yanmar diesel
67 replies to this topic
#61 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 05, 2015 - 08:15 AM
When I first started tinkering on the Perkins 3 cylinder I got from member TheFarm2004, it belched out a lot of smoke and didn't want to keep fire unless the starter was spinning.  Turned out cylinder 3 was where the main issue was, and it was turned way up.  I loosened the line and set screw at the base of #3 injector and turned it CW just a tiny bit.  It then kept running much better, but still would not shut off as the rack couldn't move #3 to kill position.  I kept moving it till it would shut down plus just a shade more.  Then I also adjusted by ear/smoke on the other 2 cylinders till she ran much smoother and shut down as she should.
#62 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted October 05, 2015 - 08:29 AM
Daniel, I have not noticed any sets crew on my pump or injectors.
#63 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted October 05, 2015 - 08:53 AM
I went back & looked at your pics, and no adjustment rings on yours.  Your fuel timing & rate must be set by shim gaskets under the pump.  I haven't ever had to deal with shimming on a diesel.
#64 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted October 05, 2015 - 09:20 AM
I know I didn't take or loose any shims from under the block but what I'm not sure of os there is a lever inside the pump from throttle arm to this block and I had the gear out and maybe put it together in the wrong spot. Any help with this is needed. Lol. Thanks
#65 Cvans OFFLINE
  • 7,293 Thanks
  • 6,380 posts
Posted October 05, 2015 - 09:27 AM
I think I have the instructions here somewhere for adjusting the timing on these engines. Will try and get back to you this evening.
Right now the fish are calling me  :D
  • limebuzz said thank you
#66 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted October 05, 2015 - 09:37 AM
Thanks Chris. That is great . Enjoy your day.
#67 Cvans OFFLINE
  • 7,293 Thanks
  • 6,380 posts
Posted October 05, 2015 - 09:26 PM
Starting on page 56 to page 65 you will find helpful information on these engines.
http://www.autoexped...nanceManual.pdf
#68 limebuzz ONLINE
limebuzz
  • 1,063 Thanks
  • 1,010 posts
Posted October 05, 2015 - 09:34 PM
Thanks a million Chris.
  • Cvans said thank you
Also tagged with one or more of these keywords: yanmar diesel
