How many Ponies?
yanmar diesel
67 replies to this topic
#16 olcowhand ONLINE
  • 41,056 Thanks
  • 31,392 posts
Posted March 12, 2015 - 05:45 PM
Found something.  I copied & pasted below. 10 to 12hp.  You can view full ad HERE.
Important Safety Warning:
Avoid fraud by meeting all sellers in-person to pay for items. Kijiji does not offer any transaction or payment services. Read More Safety Tips
Date Listed 09-Mar-15 Price
$520.00
Address 998050 Mulmur Tosorontio Townline, Lisle, ON L0M 1M0
View map
  • Description
  • Financing
Liquid cooled Yanmar 2.49 Diesel engines. Around 10-12 hp. out of thermo king heater units. 5269 hours on the engine, they commonly last up to 10 000 hours. Same overall size as kubota z482. Comes on the mounts which can be easily removed. Delivery is possible. if the add is till up, I still have it.
  • limebuzz said thank you
#17 limebuzz OFFLINE
limebuzz
  • 990 Thanks
  • 974 posts
Posted March 12, 2015 - 06:58 PM
More pics.
#18 olcowhand ONLINE
  • 41,056 Thanks
  • 31,392 posts
Posted March 12, 2015 - 07:25 PM
She is on the smaller side, so I'd say 10 to 12hp as the sale ad stated.
#19 limebuzz OFFLINE
limebuzz
  • 990 Thanks
  • 974 posts
Posted March 12, 2015 - 08:11 PM
Hmmmm. Will this be enough to power a 4850 tiller?
#20 Cvans ONLINE
  • 6,636 Thanks
  • 6,125 posts
Posted March 12, 2015 - 09:58 PM
I've got two of these engines and I think Duck hit the nail on the head. At the RPM that the governor is set at it is rated at 13 hp. Very nice engines and one of the quickest starting diesels I have run across. Placed one in a Yamaha golf cart and it made a great combination. Uses so little fuel that I forget put fuel in it. Down load the following for useful information.
http://www.autoexped...nanceManual.pdf
  • Dieselcubmike said thank you
#21 limebuzz OFFLINE
limebuzz
  • 990 Thanks
  • 974 posts
Posted March 13, 2015 - 06:18 AM
Thanks Chris. I just hope it's enough for the task it will be up against.
#22 olcowhand ONLINE
  • 41,056 Thanks
  • 31,392 posts
Posted March 13, 2015 - 06:24 AM
It shouldn't have a problem running the tiller but I have no experience with snow blowers.
#23 limebuzz OFFLINE
limebuzz
  • 990 Thanks
  • 974 posts
Posted March 13, 2015 - 12:42 PM
$520.00
View map
  • Description
  • Financing
So I was just talking with this gentleman,and it is the exact same engine as mine.He as well can't find any comfermation on the hp rating. Just my luck.
#24 angel187 OFFLINE
angel187
  • 6 Thanks
  • 11 posts
Posted March 25, 2015 - 11:17 AM
Well I started working on this project today. Mounts are too wide to fit into the frame. I removed them to mock it up inside the frame. On removal of the mounts,i uncovered a model #. Finally. Been searching for info on what I couldn't find. Cat and Smitty have been trying to help me out on this. So the # is 2TNE66K. So I looked through the manuals I have avalible and still came up empty. So can anyone help me out to figure out what hp this is?
I have all the info you need for this motor. I have one converted in my sailboat currently.
#25 UncleWillie ONLINE
  • 15,660 Thanks
  • 8,758 posts
Posted March 25, 2015 - 05:54 PM
http://sudoremont.co...e/yanmar_tn.htm
THey put one in these
http://dracoequipmen...7 PB4-101Z6.pdf
#26 limebuzz OFFLINE
limebuzz
  • 990 Thanks
  • 974 posts
Posted March 27, 2015 - 07:14 AM
Thanks, have you any specific manuals for this engine? If so,that would be great if you could share!
Paul
#27 limebuzz OFFLINE
limebuzz
  • 990 Thanks
  • 974 posts
Posted March 27, 2015 - 12:52 PM
Alright, another question for you diesel folk. As I've stated,this engine is out of a reefer unit. The alternator has a mass of wires and a condenser on the back.Do all these wire have to be hooked up?,or can I take some off? Why I ask is,there is only an inch between the exhaust and all these wires. I imagine they will get too hot and melt. I've tried to make a heat shield for between the 2 and just not enough room.
#28 Cvans ONLINE
  • 6,636 Thanks
  • 6,125 posts
Posted March 27, 2015 - 01:09 PM
Take the alternator model number and do a search on it. I have in the past been able to find wiring schematics for them. If it is a single wire alternator you can get by with one wire. From the sounds of it you are going to need at least two of or three wires.
#29 limebuzz OFFLINE
limebuzz
  • 990 Thanks
  • 974 posts
Posted March 27, 2015 - 05:49 PM
Thanks Chris, I just didn't think I'd need so many of these wires. I will check tomorrow while I'm at the shop. One more question tonight. On the side of each injecter,there is a nipple. There is a hose from one to the other injecter.but from the second one,there is nothing on that nipple. Is this like a return fuel to the tank?
#30 Cvans ONLINE
  • 6,636 Thanks
  • 6,125 posts
Posted March 27, 2015 - 09:39 PM
Your correct. It needs to return to your fuel tank above the fuel level. I've tried to return it to the main fuel line before the lift pump but this doesn't work. If you run out of fuel it is almost impossible to get the air out of the system.
  • olcowhand said thank you
Also tagged with one or more of these keywords: yanmar diesel
