Power King electrical system (adding light(s))?
4 replies to this topic
#1 zuren OFFLINE
  • 56 Thanks
  • 83 posts
Posted January 13, 2015 - 09:03 PM
What is the power generation capacity of these tractors?  I have a 1618 with the K361 engine.  I operate a lot at night so some extra light would be nice but I'm afraid traditional halogens would draw too many amps.  I haven't had any luck finding info on what the engine generates to charge the battery and possibly support additional loads.  Does anyone happen to know or have any experience?
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 13, 2015 - 09:13 PM
I'm not sure of the figures anymore but perhaps you could look into some LED work lights.  That way, it really doesn't matter all that much.
#3 glgrumpy OFFLINE
  • 8,652 Thanks
  • 7,941 posts
Posted January 13, 2015 - 09:46 PM
Think 15 amps is output on most of big K engine singles. Used to be 10, but changed to 15.  LED's don't need many amps, and won't get hot and melt something they are mounted on. Cost more tho.
  • 2,341 Thanks
  • 1,466 posts
Posted January 14, 2015 - 10:51 AM
Yes the K361 has a 15 amp charging system, as suggested LED's would be the best to hold the amperage draw down I've seen post where guys have installed them and they seem to work good.
#5 zuren OFFLINE
  • 56 Thanks
  • 83 posts
Posted January 17, 2015 - 09:15 PM
Thanks for the info.  I have been considering LEDs but you are right, definitely more expensive.
I was planning to add a battery box and mount my switches to it so I don't drill any permanent holes in the tractor.  I want to make up some brackets that use the fender mounting bolts for the forward facing lights to accomplish the same thing (no holes in the tractor).  But I also has a 5 month old baby so we'll see how many tractor project I can start/finish.
