Hydro/differential oil?
20 replies to this topic
#1 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted January 13, 2015 - 08:06 PM
I've got the manual that says to put 90 weight oil in the differential but I cannot find where to fill nor have I heard this talked about? I didn't know you had to put separate oil in the diff than the hydro. This is my first jake and I'm just not familiar wih it.
#2 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted January 13, 2015 - 08:26 PM
Don't feel lonely! I'm learning right along with you!
  • Unstuck747 said thank you
#3 Tomwendt ONLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted January 13, 2015 - 09:33 PM
fill hydro under seat pan.fill rear end on right side through plug hole till full.i got my jake from the scrap yard and this worked fine for me.
  • KennyP and Unstuck747 have said thanks
#4 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted January 13, 2015 - 09:48 PM
So the hydro and rear end are separate oils then?
#5 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted January 13, 2015 - 10:20 PM
What oil did you use in the rear end?
#6 Tomwendt ONLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted January 14, 2015 - 09:26 AM
80-90 in rear end. Type 111 dextron in the hydro.
#7 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted January 14, 2015 - 09:45 AM
Thanks, Tom! I have a new filter for the Hydro, so will change the fluid in it when temps warm some. Need to find that fill plug for the rear end. The 'Drive/No Drive' selector is real stiff, may have to remove it and see what's happening there. Could be a low oil situation?
#8 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted January 14, 2015 - 01:59 PM
Mine doesn't move at all the knob just slips on the rod coming from the hydro
#9 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted January 14, 2015 - 03:30 PM
I don't have a knob. Been using channel locks to turn it.
#10 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted January 16, 2015 - 06:08 PM
Where's the drain plug for the hydro?
#11 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted January 27, 2015 - 06:10 AM
I haven't found a plug on the right side as yet. I have to pull the tires, will look then!
I put some Acetone/ATF mix on there and mine loosened right up. Made a knob to fit. Have to get a pic of that.
I'll be checking fluids today. I'll have some pics. But I haven't seen a drain for the hydro as yet.
#12 Tomwendt ONLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted January 27, 2015 - 09:26 AM
Download the jacobson hydro gear manuel.page 18 number 35 is the drain plug.
#13 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted January 27, 2015 - 09:29 AM
How much oil does it take to fill after draining?
Found it!
#14 Tomwendt ONLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted January 27, 2015 - 09:59 AM
About 2 quarts.fill to 1 inch below the fill hole.
#15 KennyP ONLINE
  • 37,580 Thanks
  • 45,541 posts
Posted January 27, 2015 - 10:04 AM
Thanks, Tom! I'll be installing a new filter also!
