C81needed a little hub TLC.
1 reply to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted January 13, 2015 - 05:01 PM
This C81 is a pretty nice tractor the only issue that I have found with it so far is the worst worn out hub that I have ever seen. I had a spare set on the shelf so I pulled the worn hub off and put a fresh hub on. Now it's ready to push,pull,or mow ! I hit the paint quick with rubbing compound,I still need to finish that up,paint the wheels and replace the seat. I also recently picked up a very solid complete 42 inch rear discharge deck in great shape,including the covers. The only issue is there is no paint left on it. I hope to get it sand blasted and painted before spring. I plan to use the tractor for a back up mower this year. Forgot to add that the hub was so loose it would spin an 1 1/2 inch or more on the axle before engaging and was held in place with collars with set screws,one behind and one in front of the hub.
Edited by rustyoldjunk, January 13, 2015 - 05:09 PM.
  • Sawdust said thank you
#2 Sawdust OFFLINE
Sawdust
  • 6,010 Thanks
  • 3,490 posts
Posted January 13, 2015 - 07:43 PM
I like the C81 good looking around tractor. I just completed my wish list last summer of five. I may just start a new list with the C81 on there for this year. I need to edjamacate myself some on the WH first :) It's a good thing you had a hub those things have gotten outrageous.
Edited by Sawdust, January 13, 2015 - 07:44 PM.
