Steering Problem on 102
39 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,662 Thanks
  • 3,195 posts
Posted January 11, 2015 - 08:37 PM
It will turn to the right but when trying turn to the left the whole steering almost twist out. What do yall think is the cause of it ? I haven't got to look at it because it stuck in the field cause of the steering I really hate being out in the weather.
#2 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted January 11, 2015 - 08:49 PM
My 102 had major steering issues when I dug into it finally. Turned out the steering column needed some adjustable fasteners snugged up. Of course to do that easily one must remove it to the see it. When I did it all came apart because mine was worn out. Undo two bolts and the draglink and the steering column drops out the bottom with the steering wheel off. If need be I have one out of a JD 210 that should fit fine.
Here is a picture of my steering column removal setup. (next post)
  • bbuckler said thank you
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted January 11, 2015 - 08:50 PM
The steering wheel on my Cub Cadet came off of said JD 210 as my original was junk.
Edited by wvbuzzmaster, January 11, 2015 - 08:51 PM.
#4 bbuckler ONLINE
bbuckler
  • 3,662 Thanks
  • 3,195 posts
Posted January 11, 2015 - 08:58 PM
It look like a job to do this weekend it going to be 61 and sunny.
  • wvbuzzmaster said thank you
#5 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted January 11, 2015 - 09:14 PM
Could be perfect time to do it. I also rethreaded my draglink to make it shorter to make the steering radius the same both left and right.
When I pulled the steering column in my Cadet I made sure the other I had was ready to go in, but my column had bigger issues. If you are interested the JD210 is a parts tractor.
#6 bbuckler ONLINE
bbuckler
  • 3,662 Thanks
  • 3,195 posts
Posted January 11, 2015 - 09:20 PM
Let me talk to my mom it her tractor I just get to work on it.
#7 bbuckler ONLINE
bbuckler
  • 3,662 Thanks
  • 3,195 posts
Posted January 11, 2015 - 09:22 PM
She asked how much you want for it ?
#8 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 11, 2015 - 09:30 PM
Blasphemous!  John Deere parts on a International Harvester machine!
Ben W.
  • wvbuzzmaster, EricFromPa, tinbender7 and 1 other said thanks
#9 bbuckler ONLINE
bbuckler
  • 3,662 Thanks
  • 3,195 posts
Posted January 11, 2015 - 09:48 PM
Ben W.
 If it get the job done that all that matters to me.
  • wvbuzzmaster and superaben have said thanks
#10 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Ben W.
Rule one, when the real one is over 50 bucks, and you have one that fits and works, grab it and use it. Besides, no one collects them John Deeres anymore, Cub Cadets are where it's at. :D
Ps: Troy will appreciate that comment. :poke:
Edited by wvbuzzmaster, January 11, 2015 - 09:49 PM.
  • EricR, superaben, toomanytoys84 and 1 other said thanks
#11 EricFromPa ONLINE
EricFromPa
  • 3,981 Thanks
  • 3,253 posts
Posted January 11, 2015 - 09:55 PM
Sounds like the top bearing fell apart.They are pretty simple to rebuild.Only hard thing is getting the wheel off without ruining it.
The Kits are really expensive on Ebay.The price is almost laughable.
http://www.ebay.com/...=item2a4a438377
You might be able to just replace the 2 bearings and races if the rest of the parts look OK.
http://hamiltonbobs....cadet-108-mm971
#12 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 11, 2015 - 10:11 PM
That'll be a day, when green and yellow stops being the thing to have.  :rolling:
Ben W.
  • wvbuzzmaster and GTpicker01 have said thanks
#13 DH1 ONLINE
DH1
    Electric Tractors
  • 5,366 Thanks
  • 5,605 posts
Posted January 11, 2015 - 10:16 PM
Cub Cadets are where it's at   ???  What about SPRINGFIELDS  ???
#14 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted January 11, 2015 - 10:20 PM
First of all this thread is about Cub Cadets. Second of all, I am trying to keep the price of Springfields down for myself. Lol
  • DH1 said thank you
#15 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 11, 2015 - 11:25 PM
Casey is broadening his horizons a bit, aren't you proud of him?  :poke: :smilewink:
Ben W.
