I know we've thought about it but
22 replies to this topic
#16 bryan 110 OFFLINE
bryan 110
  • 222 Thanks
  • 293 posts
Posted January 11, 2015 - 09:40 PM
I plan on doing one this summer. Using a original cub cadet deck Briggs 4wheels metal frame and for hight adjustment I plan on using a drag section depth leaver
#17 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted January 12, 2015 - 01:50 PM
I keep thinking about doing the same thing. I have two different types of decks. Ones that were used with a vertical motor and belt and another that has a gear box on the top of the deck from a shaft drive.
I keep wondering if I were to have a rear PTO and attach a shaft to the one that has a gear box maybe I could use it like a brush-hog. :pushmower:
#18 GreenAcreHomestead OFFLINE
GreenAcreHomestead
  • 2 Thanks
  • 2 posts
Posted July 30, 2015 - 12:11 PM
Hey.... that deck looks like a snapper... could it be???  :rocker2:
#19 poncho62 ONLINE
poncho62
  • 2,254 Thanks
  • 1,836 posts
Posted July 30, 2015 - 07:04 PM
Poncho has one, Ford deck self powered pulled by a GT, either straight behind or offset.
I know its an old thread,,,,built this a few years ago...It worked OK......I dismantled it recently......I just dont have a use for it now.
  • DH1 and Alc have said thanks
#20 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 01, 2015 - 09:29 AM
Poncho, do you happen to have a writeup on this build?? With lots of pictures on how you did this??
#21 poncho62 ONLINE
poncho62
  • 2,254 Thanks
  • 1,836 posts
Posted August 01, 2015 - 03:56 PM
I am sorry, but I dont....I have a couple of pics, but they dont show a whole lot....
What I did was, took the Ford deck and put the front part of a cheapo MTD type tractor on top of it. Looking at the pics, you can see what I mean. The vertical shaft of the B&S engine drives the pulley of the Ford deck. I put an idler pulley under there that tightens the belt so it can be turned on and off. That extra handle sticking up does this....The pulleys is something I should have taken some pics of.
Here is a few pics I did take
#22 dodge trucker ONLINE
dodge trucker
  • 2,913 Thanks
  • 3,533 posts
Posted August 02, 2015 - 10:30 PM
I stumbled onto a Swisher Trailmower last year that I am just now gettin around to fixing up; 44" finish mower, orig engine was a 10-1/2HP Briggs, long gone, PO bolted a 14HP single cyl Vanguard to it but never finished it up, I have to rig a gas tank for it and a battery tray, (orig was pull start and self contained gas tank within engine shroud)
just gotta weld up a couple brackets and those will be done. Just got it totally dismantled and out for sandblasting yesterday///once the original (and coming-apart) powdercoat and rust are gone I can do my welding
#23 victor3ranger OFFLINE
victor3ranger
  • 316 Thanks
  • 630 posts
Posted August 05, 2015 - 12:55 PM
Thank you for the pics.  I didn't even think about using the platform the motor originaly was attached to.
