I know we've thought about it but
22 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted January 10, 2015 - 10:53 PM
Has anyone had any successful luck building a pull behind mower? You know something made from a old deck.
  • Sawdust, FrozenInTime and propane1 have said thanks
#2 shorty ONLINE
shorty
  • 5,838 Thanks
  • 5,418 posts
Posted January 10, 2015 - 11:00 PM
I saw one a few years back at an auction. The guy had built a frame for it to hang off of. It actually was a fairly nice build.
#3 FrozenInTime OFFLINE
FrozenInTime
  • 658 Thanks
  • 404 posts
Posted January 10, 2015 - 11:01 PM
I have the deck from my Snapper but have no plans to use it, unless.... been thinking about turning it into a 3-point deck so I can hook or un-hook it quickly.
#4 DH1 ONLINE
DH1
    Electric Tractors
  • 5,436 Thanks
  • 5,619 posts
Posted January 10, 2015 - 11:05 PM
Poncho has one, Ford deck self powered pulled by a GT, either straight behind or offset.
  • MH81, KennyP and BairleaFarm have said thanks
#5 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted January 10, 2015 - 11:06 PM
I'm thinking about it. No need for 3ph but decks abs vertical shaft motors are fairly common around here.
#6 BTS ONLINE
BTS
    Make Stuff Up
  • 4,643 Thanks
  • 2,617 posts
Posted January 10, 2015 - 11:39 PM
I built one out of a "newer" cub cadet 48" deck, I don't have pictures though. I built it about 6 years ago, I made a frame to hang the deck off of and I had a small JD rear engine mower that was junk (was ran over by a large pickup) anyway, the engine was good so I just cut off the whole rear end/engine mounting platform and welded it straight on top of the deck. The engine was a Kawasaki 8hp vertical shaft and I think a bigger engine would of done a lot better, but it did work good if you didn't run in high gear.     If you hang the deck off chains (like I did) it is easy to adjust the height and if the deck bumps into a tree or ect, it swings out of the way.
Good luck! :wave:
  • KennyP and tinbender7 have said thanks
#7 KennyP ONLINE
  • 40,949 Thanks
  • 47,132 posts
Posted January 11, 2015 - 05:43 AM
I have a deck I have thought about doing that to. Also have a B&S 18 HP vertical shaft to power it. Just haven't decided if I want it as a full tow behind or not.
  • tinbender7 said thank you
#8 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted January 11, 2015 - 08:52 AM
Years ago I only needed a small pull behind I made from ganging a few old rotary mowers together. They worked nice but I don't have them anymore. If you go on YouTube & do a search for "DIY pull behind mowers" you'll find a lot if them for ideas.
  • oldedeeres said thank you
#9 drbish OFFLINE
drbish
    Collecter
  • 1,575 Thanks
  • 1,372 posts
Posted January 11, 2015 - 08:58 AM
I uploaded this to the Simplicity Implement section.
http://gardentractor...railing-mowers/
  • MH81, KennyP, farmerall and 1 other said thanks
#10 Arti OFFLINE
Arti
  • 1,371 Thanks
  • 995 posts
  • Location: South West Wisconsin . Now in North Central Mo.
Posted January 11, 2015 - 09:06 AM
An old Dixon Zero turn would only need a hitch put on it and you would have a nice pull behind..
The ones with a worn out cone drive would be an ideal candidate.
  • Sawdust said thank you
#11 Traill95 OFFLINE
Traill95
    Traill95
  • 1,859 Thanks
  • 1,021 posts
Posted January 11, 2015 - 10:31 AM
CRFarnsworth built one but it is electric.
  • CRFarnsworth said thank you
#12 dodge trucker ONLINE
dodge trucker
  • 2,824 Thanks
  • 3,458 posts
Posted January 11, 2015 - 10:42 AM
I saw onw built from a Sears Suburban/SS deck about 10 years ago, that guy did an awesome job
#13 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,724 posts
Posted January 11, 2015 - 11:17 AM
A fellow had an electric GT and made a pull behind mower (electric also) and was showing it at the Garden Tractor Extravaganza a year or 2 ago....Neat looking and he said he used it once to make sure it was functionable, but made it for show.
Edited by KC9KAS, January 11, 2015 - 11:18 AM.
  • CRFarnsworth and Traill95 have said thanks
#14 Traill95 OFFLINE
Traill95
    Traill95
  • 1,859 Thanks
  • 1,021 posts
Posted January 11, 2015 - 12:13 PM
I believe that was my brother Rick, on here as CRFarnsworth(The Rat Fink avatar).gallery_6275_658_106112.jpg
Edited by Traill95, January 11, 2015 - 12:19 PM.
  • KC9KAS and oldedeeres have said thanks
#15 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,724 posts
Posted January 11, 2015 - 12:37 PM
That's it!
Thanks for the photo to help me out!
  • Traill95 said thank you
