Building 3-pt on Bolens HT23
4 replies to this topic
#1 BTS ONLINE
BTS
    Make Stuff Up
  • 4,254 Thanks
  • 2,457 posts
Posted January 10, 2015 - 10:00 PM
Ok, I just got a blade on the front of my HT23 and now I'm wanting to get a 3-pt set up on it.
I already have a 3-pt hitch, I got it on trade, I dug up a water line with my backhoe and he gave me this 3-pt. I already had a cylinder, I also have another 1 way cylinder but it is a lot smaller bore so I don't know if it will be enough? I'm going to build this 3-pt on a plate and then bolt it on the rear end. Would this be strong enough if I just bolt this to the rear end? or should I build my mount to hang on the existing 3-pt mounts on the axle and then still have it bolt on top??? The most I'm going to lift is a 4' box blade with about 300lbs of wheel weights on it. But I don't want to do any damage to the rear end.
I'm going to start building this weekend and I'll see how far I get.
Edited by BTS, January 10, 2015 - 10:07 PM.
  • case442 and Traill95 have said thanks
#2 BTS ONLINE
BTS
    Make Stuff Up
  • 4,254 Thanks
  • 2,457 posts
Posted January 11, 2015 - 11:30 AM
Does anyone know what pressure the hydraulic system has?
Thanks for any info :wave:
#3 OldBuzzard ONLINE
OldBuzzard
  • 7,024 Thanks
  • 4,792 posts
Posted January 11, 2015 - 11:34 AM
I'm not sure, but I would look in the Large Frame service Manual.  It's very possible that it's in there.
http://gardentractor...service-manual/
Edited by OldBuzzard, January 11, 2015 - 11:35 AM.
#4 BTS ONLINE
BTS
    Make Stuff Up
  • 4,254 Thanks
  • 2,457 posts
Posted January 11, 2015 - 11:59 PM
From what I found, this tractor should have between 550 to 800 PSI.
Thanks for the link
#5 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted January 12, 2015 - 12:02 AM
Thanks for the link
Thats with what RPM you run the engine at...
