Kohler K341. Flat bottom Vs. deep pan oil sump?
25 replies to this topic
#16 olcowhand ONLINE
  • 37,225 Thanks
  • 30,213 posts
Posted January 11, 2015 - 10:27 AM
I found this picture of an 16hp engine that came out of a MF1650, looks like it's a wide base block with a small pan. ???
Yes, that is an AQS like Will has buried past the snowpack.  I think Will is best off to wait till that engine can be gotten to.  Both 1650's I owned had shallow aluminum pans with a deep sump in them at the rod area.
  • DH1 said thank you
#17 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 11, 2015 - 10:47 AM
Here's all the pans listed in the Parts manual.
#5 is the pan on the Ford. #8 is the pan on the AC.
  • Alc and IamSherwood have said thanks
#18 limebuzz ONLINE
limebuzz
  • 936 Thanks
  • 921 posts
Posted January 11, 2015 - 11:11 AM
I know it ain't pretty or anything, but this is what I built to convert a wide pan to the little aluminum one for the MF 1650 that I have.
  • Alc, IamSherwood and KennyP have said thanks
#19 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 11, 2015 - 12:26 PM
I thought about something like that!
#20 limebuzz ONLINE
limebuzz
  • 936 Thanks
  • 921 posts
Posted January 11, 2015 - 01:49 PM
Just putting it out there. Seal it up good and it will work good.When all else fails,make it work
#21 olcowhand ONLINE
  • 37,225 Thanks
  • 30,213 posts
Posted January 11, 2015 - 02:03 PM
Doesn't have to look pretty....just has to work!  :thumbs:
#22 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted January 11, 2015 - 11:29 PM
Well, I got it done.
That was a heck of a marathon day.
Looks like you guys figured out the same thing I did.
You can take a AQS block, and put it on a S flat sump, but
not the other way.
Here's some pics of the 1st half of the day.
I made it back to Massey Hall.
Back there in front of the yellow tiller is the grey AQS.
Rigged up a block, and got it hanging.
Moved some of the other girls out of the way, set it on the Sears, and strapped
it down.
Backed the Sears out.
And headed back to the truck.
http://youtu.be/kKZ4N8s8G-g
When swapping the blocks and pans, I discovered what caused the engine
failure, but I don't know why the dipper would have broken off.
I also had to swap the flywheel so the driveshaft would fit, swap the oil fill
tube, and monkey with the muffler a bit. I got the new engine installed and
running. All I need to do yet, is hang the blower, and I'll be back in
business.
  • DH1, limebuzz, Alc and 1 other said thanks
#23 KennyP OFFLINE
  • 32,212 Thanks
  • 42,021 posts
Posted January 12, 2015 - 05:38 AM
Ouch! Looks like more than just the dipper in there!
  • IamSherwood said thank you
#24 IamSherwood OFFLINE
  • 8,382 Thanks
  • 7,696 posts
Posted January 12, 2015 - 08:50 AM
Idk Kenny. They look to be dipper bits. I haven't taken much time to look
any farther in that block. Maybe later today. First I need to catch up on
the snow blowing.
#25 olcowhand ONLINE
  • 37,225 Thanks
  • 30,213 posts
Posted January 12, 2015 - 09:01 AM
Will, I had a K341 in an Allis 416 do the exact same thing.  Mine didn't toss the rod either, as I felt it binding up while mowing & shut her down quick!
#26 dodge trucker ONLINE
dodge trucker
  • 1,627 Thanks
  • 2,140 posts
Posted January 20, 2015 - 10:53 PM
3 and 8 look the same as each other..  I have never ever seen anything like 7, 10 or 22.
