Kohler K341. Flat bottom Vs. deep pan oil sump?
25 replies to this topic
#1 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 10, 2015 - 09:48 PM
My main snow blowing machine decided to pack it in yesterday.
I need to get it going soon. We've been getting dumped on for the
past 4 days. About 3 ft by now.
It has a Kohler K341s with the flat bottom oil sump.
I have a freshly rebuilt ( 2 yrs ago ) with 0 hrs on it K341AQS
sitting on the shelf. It has the deep oil sump, the kind you'd
find in a MF1650.
My question is, can I take the block and all the guts of the AQS, and
put it on the flat sump? I assume the oil dipper is longer on the AQS?
Can I just shorten that, and bolt it down?
Any help appreciated
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted January 10, 2015 - 09:57 PM
Oh no, Will!  That was kind timing...
If you know your type numbers, I will check and see what the difference is.
Ben W.
  • IamSherwood said thank you
#3 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted January 10, 2015 - 10:06 PM
The motor has to come out of your 14/16, see if the blocks are same and swap over the pans if you can. Rod dipper might be the same. ???
#4 limebuzz ONLINE
limebuzz
  • 1,000 Thanks
  • 976 posts
Posted January 11, 2015 - 04:29 AM
I think I've tried this and the pans do not interchange. When you bolt the pan down to block,there is a gap that oil will spew out of. It's been a bit now,but I'm sure it won't work.But,good luck.
#5 boyscout862 ONLINE
  • 12,851 Thanks
  • 9,171 posts
Posted January 11, 2015 - 08:03 AM
Nice looking cab and tractor. I've found that there are different types of Kohler blocks and they do not interchange between my Cubs and my Ford LGTs. Good Luck, Rick
#6 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted January 11, 2015 - 08:08 AM
I have a wide base K341 I WAS going to put in the Ford. Didn't pull it yet if the pan is not going to work!
#7 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 11, 2015 - 08:17 AM
I did some looking at agcopartsbooks.com
The deep sump K341  uses the same connecting rod as flat sump version.
Then, using the spec # for the short blocks which I got off agco, I then searched
through partstree.com and looked at both the deep and flat sump short blocks.
They both refer you towards a section guide of the same # TP-2076-D
Sounds good so far.
Being the K341aqs (the one I want to use) is on a shelf
back in Massey hall, and there's about 200 yrds of 1 ft deep snow that I have
to deal with (without my blower), I was looking for some sort of comforting
feeling that this might work, before I go through that exercise.
Well, it's still snowing, so I better get at it.
  • limebuzz, KennyP, boyscout862 and 1 other said thanks
#8 esbbent OFFLINE
esbbent
  • 403 Thanks
  • 239 posts
Posted January 11, 2015 - 08:49 AM
Will,
If I am not mistaken you should be able to take the pan off the k341 (from the mower) and put it on the K341aqs.
BTW, my MF8 with the K181 started knocking while I was blowing some snow yesterday. Not a good day for either one of us. Plan on tearing the engine apart today to see what happened.
Ted
#9 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted January 11, 2015 - 09:00 AM
Here's a pic of the 3 different blocks from the bottom.
  • Alc, IamSherwood, Trav1s and 1 other said thanks
#10 olcowhand OFFLINE
  • 41,151 Thanks
  • 31,416 posts
Posted January 11, 2015 - 09:14 AM
Kenny's pic shows a K341S on the left, the center is a K341AQS, the one on right is like used on Cub Cadets.  Most (but not all) K341's like to the left have those notches under the block mount "wings", and you can't use the AQS sump on them.
  • Alc, IamSherwood and KennyP have said thanks
#11 KennyP ONLINE
  • 38,343 Thanks
  • 45,918 posts
Posted January 11, 2015 - 09:25 AM
I'm thinking the Ford's AQS is more square like the last pic. I know it doesn't have the 'wings' like the first two have.
  • olcowhand and Alc have said thanks
#12 olcowhand OFFLINE
  • 41,151 Thanks
  • 31,416 posts
Posted January 11, 2015 - 09:29 AM
I am with you on the Ford to the right.  Having owned only one Ford, and been a while, I wasn't sure my memory was correct.
#13 EricFromPa OFFLINE
EricFromPa
  • 3,658 Thanks
  • 3,113 posts
Posted January 11, 2015 - 09:40 AM
You can use a wide pan block if your willing to do some welding and tap the bolt holes.
If the blocks are the same and the only difference is the Oil Sump,You can cut the Dipper and round off the edges with a file.
Found this guide on converting wide based blocks.Haven't done this myself but it looks like it will work.
http://gardentractor....com/oilpan.htm
#14 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted January 11, 2015 - 09:52 AM
I checked my 2 - MF16's and I have a parts engine from a MF14 and they are all the wide base blocks, with the wings on them.
Like the 2 in Kennys picture, left and center.
I guess that's what they put in the 14/16 tractors.
#15 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted January 11, 2015 - 10:17 AM
I found this picture of an 16hp engine that came out of a MF1650, looks like it's a wide base block with a small pan. ???
