Kenny P needed the measurements from my sleeve hitch on the 416 so I decided to make a thread so anyone else needing them would have them.
The hitch is made out of two inch bar stock one quater inch thick. The length is measured at nine and a half inches OD. The width is seven inches OD.The center brace is welded in four and three quarters ID from the rear of the hitch and the lift brace is welded exactly centered. The sleeve for the hitch pin is made of one inch thick wall tubing. The lift rod is seven inches long from the outside of the bend where it goes into the lift arm on the tractor. The threads on the clevis end are threaded two and a half inches on the lift rod and the clevis on mine is threaded to where the threads are flush on the inside.
The corners of the hitch that mount to the tractor are rounded so they do not catch when the lift is raised or lowered. You will have to drill a hole on each side of the hitch pin tube from the back side. The adjusting bolts are half inch by three inches and after you tighten the bolts and nuts you can weld the nut to the inside of the hitch and use two more nuts as lock nuts to hold the bolts in adjustment.
Edited by KennyP, January 13, 2015 - 07:17 PM.
