Why me , hyds n 314
7 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 09, 2015 - 10:45 AM
Well with the help of those on our forum I finally got my h2 hyds from a 317 on my 314 .
No. 1  Started tractor had a small leak from a line I didn't have tight .
No. 2  Pushed outside lever forward and had hyd all over tractor and garage!!!
No. 3  The hardest line to install goes over brake cross shaft kas a hole in it I didn't see when I installed it.
So I'm going to replace with a hose instead of steel line.
larryd
#2 KennyP OFFLINE
  • 40,925 Thanks
  • 47,117 posts
Posted January 09, 2015 - 10:47 AM
That sucks! Things should be lubed good now!
#3 hdg4400 ONLINE
hdg4400
  • 294 Thanks
  • 358 posts
Posted January 09, 2015 - 11:52 AM
larryd:
I replaced the primary return tube with high pressure hose and clamps from NAPA on my old JD 140. Had that tube break 3 or 4 times, and still have a spare of that part (AM33284) that I don't need. Anybody out there need this part? Never been used, and going cheap.
Harlan
  • Oldford said thank you
#4 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted January 09, 2015 - 03:09 PM
Better now than out in the yard while working, Glad it's gonna work for you
#5 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted January 11, 2015 - 07:35 AM
Glad you got it going Larry. It's a major rats nest of shafts and hydraulic lines under there. Really not setup well at all from a maintenance point of view.
#6 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,165 Thanks
  • 1,332 posts
Posted January 11, 2015 - 07:59 AM
One point I have pondered over the years is if the designers and engineers of powered outdoor equipment have very small hands.
#7 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 12, 2015 - 06:39 AM
They probably don't have to work on them. Same goes for automobiles . Big block Mustangs and Fairlanes etc.
larryd
  • Cat385B said thank you
#8 Cat385B ONLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,140 posts
Posted January 12, 2015 - 09:50 AM
larryd
New trucks, etc......
