IHC hit and Miss engine restoration
22 replies to this topic
#16 Cvans ONLINE
  • 7,068 Thanks
  • 6,286 posts
Posted January 09, 2015 - 11:53 AM
That crankshaft is salvageable. There are places that can build those journals up and then machine them to specs. Spray welding is one process used for this purpose. Take a look at this thread as there are a number of businesses listed that can help you.
http://www.smokstak....ad.php?t=123123
  • farmerall and propane1 have said thanks
#17 farmerall OFFLINE
farmerall
  • 2,207 Thanks
  • 1,475 posts
Posted January 09, 2015 - 12:19 PM
Spent a little time looking. From what I can find these were built 1911-1917. I'm thinking the brass rod ended in 14 or 15. It woud be worth a shot at the crank. Start sanding it easy and watching. There is also an acid that will raise the stamped numbers since that metal is compressed harder than the metal around it.
What is the name of the acid?  I'm also thinking of try electrolysis to clean up the rust on the flywheels and governor parts. At some point I will need to pull the flywheels off of the crank.
#18 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 09, 2015 - 03:44 PM
Ok it looked bigger in the pictures,  Sandblasting would really make them shine.
#19 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted January 09, 2015 - 04:28 PM
Awesome find and I am subscribing to the thread to see it's progression. I love seeing the hit and miss engines at the shows and listening to them.
  • Little Irish Men said thank you
#20 propane1 ONLINE
propane1
  • 9,120 Thanks
  • 4,275 posts
Posted January 09, 2015 - 06:32 PM
Spray welding is something I just heard of about a month ago.  I was told its expensive, its worth it if repairs it. Learn something new every day.  Great to see it getting fixed up. love the sound of the old engines running.    Noel
  • Cvans said thank you
#21 Bill 76 ONLINE
Bill 76
  • 2,001 Thanks
  • 1,204 posts
Posted January 10, 2015 - 03:56 AM
You can also have the crank journals hard chromed and reground to size.
  • Cvans and propane1 have said thanks
#22 DougT OFFLINE
DougT
    Dog Approved
  • 7,073 Thanks
  • 5,058 posts
Posted January 18, 2015 - 03:20 PM
Here is a good site on restoring serial numbers. It shows the most common used solutions. not sure how much of this the average person can buy. I was given a small amount of solution years ago by a detective checking a car in a dealership I was working at to help see a serial number in an old tractor. It worked good.
#23 Jazz ONLINE
Jazz
  • 2,586 Thanks
  • 1,519 posts
Posted January 25, 2015 - 03:43 PM
Be cautious what acids you use....I know for a fact vinegar will eat cast. I have vat of vinegar for cleaning rust off of STEEL parts only...I put a brake drum in there for a week just to see what would happen....I could peel layers of the inner drum out with a putty knife....
  • farmerall said thank you
