Kohler flywheel pulley options
kohler flywheel
29 replies to this topic
#16 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted January 09, 2015 - 08:44 AM
I read in some thread here that the Kohler powered PKs used the flywheel side for PTO. Maybe that is all you need, a PK PTO clutch setup?
  • NUTNDUN and KennyP have said thanks
#17 TAHOE ONLINE
TAHOE
  • 7,973 Thanks
  • 5,674 posts
Posted January 09, 2015 - 12:18 PM
 The project might be over my head or more of an undertaking than I think it is going to be.
Chicken   :poke:  :D
Seriously the flywheel issue is not really any issue in my mind if you can find a pulley or adapter to bolt up to it to drive snow blower pulleys or driveshaft. My AC HB212 had the Briggs mounted with flywheel side toward the rear bolted to the driveshaft which drives teh hydro. I don't think there is an issue dricing off flywheel as long as proper direction, it's just the logistics of getting it bolted up.
  • NUTNDUN said thank you
#18 Bud W ONLINE
Bud W
  • 325 Thanks
  • 302 posts
Posted January 09, 2015 - 12:34 PM
My Bolens Large frames have a stub shaft that bolts to the Kohler K482 flywheel but I don't think it will bolt up to your Kohler but you might be able to adapt it. My dad made a stub shaft for a Briggs and Stratton that boles to the flywheel. My buddy also made one for one of those chinky- chong engines that bolts to the flywheel to make one of his machines move the correct direction.
  • NUTNDUN and Alc have said thanks
#19 propane1 OFFLINE
propane1
  • 8,722 Thanks
  • 4,126 posts
Posted January 09, 2015 - 05:55 PM
Does some one have a picture of an electric pto bolted to the flywheel side of the engine, I cant seem to figure that out.  Thanks, Noel
#20 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted January 11, 2015 - 05:41 PM
Ok, had a chance to get a couple of pictures yesterday to show how much room is in from of the engine on the Bush Hog HD-12 and what the blower mount looks like. I think it will work. Hardest part will be making up the bracket and figuring out which electric PTO I need. A PTO shaft won't be too hard to make up depending on how I make the bracket up.
Here are the pics:
  • Alc, IamSherwood and propane1 have said thanks
#21 limebuzz ONLINE
limebuzz
  • 997 Thanks
  • 976 posts
Posted January 11, 2015 - 06:05 PM
George, I think the rotation will be the opposite of what you need for that blower.
#22 olcowhand ONLINE
  • 41,098 Thanks
  • 31,403 posts
Posted January 11, 2015 - 07:09 PM
George, the rotation will be wrong.  The 1655 has the flywheel side running the hydro, while your HD-12 has the flywheel to the front.  You would need to find an opposite rotating gearbox for the snow blower, and move any chain tensioners to opposite side of the chain loop.  If the gearbox on the blower says LF on it, then you need one that says RH or vice-versa.
#23 glgrumpy OFFLINE
  • 8,606 Thanks
  • 7,913 posts
Posted January 11, 2015 - 07:27 PM
Use something else for this winter for snow and buy another tractor with the right blower on it in summer!!  No need to re-engineer a product that way!
#24 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted January 11, 2015 - 07:28 PM
Well that sucks. Puts a thorn right into the project. For some reason I thought the flywheel side ran the electric PTO on the Massey 1655.
#25 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted January 11, 2015 - 07:29 PM
I just need to find a proper blower for my Bush Hog HD-12. Already have a Massey MF12 with the snow blower on it. Just thought it would be nice having that big blower mounted up on the Bush Hog.
  • IamSherwood and propane1 have said thanks
#26 IamSherwood OFFLINE
  • 8,391 Thanks
Posted January 13, 2015 - 06:48 AM
I saw in your pictures, that
the K341 has the air breather off a K321 on it.
Am I remembering correctly, that you had some
issues getting that K341 to run correctly when you
installed it?
Back in Nov. when I built my snowblower, I couldn't get
it to run properly with the smaller breather/filter. I put the correct
one on, and all was good.
http://gardentractor...e-2#entry512418
Just something I noticed.
#27 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted January 13, 2015 - 07:00 AM
installed it?
Thanks Will.
I will try and find the proper air cleaner assembly. I didn't realize it was the wrong one since it was on the engine when I got it. The Kohler runs great though now. The issue with mine was the screw to adjust the points had loosened up just enough for the timing to go out of adjustment.
  • IamSherwood said thank you
#28 Alc OFFLINE
  • 6,884 Thanks
  • 7,459 posts
Posted January 13, 2015 - 08:41 AM
Is there any way of running the blower from the rear pto or what ever is used for mowing forward ?  I think there are lots of tractors that run a pto from front to back like the tiller on my Jim Dandy , some of the Fords had a shaft running back too . Maybe you could make up something like those to drive the front ?
#29 TAHOE ONLINE
TAHOE
  • 7,973 Thanks
  • 5,674 posts
Posted January 13, 2015 - 01:46 PM
could you somehow mash a belt pulley ( like an old starter/gen pulley on old motoros) between driveshaft and back of motor, like old SBC pulleys bolted on the balancer, run as belt down and then mount a jack shaft to run a longer driveshaft going out the front....if you want to try to keep this alive.
  • Alc and IamSherwood have said thanks
#30 olcowhand ONLINE
  • 41,098 Thanks
  • 31,403 posts
Posted January 14, 2015 - 08:36 AM
Daniel...wrong thread?
LOL...yes!   Moved it, thanks.
Also tagged with one or more of these keywords: kohler, flywheel
