Jacobsen 59713 Tiller(s)
jacobsen attachments jacobsen tiller super chief 1450 tiller
41 replies to this topic
#16 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 19, 2015 - 05:37 PM
You don't want to lift that big slug by hand?
NO SIR!
#17 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 21, 2015 - 04:53 PM
Kinda figured someone would have some info on actuators by now!
#18 Tomwendt OFFLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted January 21, 2015 - 06:51 PM
me too
#19 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 22, 2015 - 07:19 AM
Found a 6" stroke, 400 lb. force actuator on Ebay for under $100. Thinking about getting it.
Edit: won't work. Hole dia. on mount is too small! Need 1/2", this is .4"
#20 Tomwendt OFFLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted January 22, 2015 - 08:32 AM
You mean like this?
#21 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 22, 2015 - 08:55 AM
Yes! What size is that one?
#22 Tomwendt OFFLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted January 22, 2015 - 09:18 AM
1/2 inch it's new .was used on street sweepers.i paid 20.00 for it.
#23 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 22, 2015 - 09:40 AM
What's the stroke length? Are you saying the mount holes are 1/2"? Has it got a brand name on it?
#24 Tomwendt OFFLINE
Tomwendt
  • 133 Thanks
  • 148 posts
Posted January 22, 2015 - 10:53 AM
It's a Warner.mounting holes are 1/2 inch .the stroke is at least 4 inches.
#25 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 23, 2015 - 06:00 PM
Tom and I have stuck a deal on the actuator. I should have it by next weekend. I need to get out there and fire the Jake up and see why it is not charging. I checked continuity on the stator and it shows to be good. The regulator is one of the older large finned type like what is on the AC416S. Here's a pic.
I cannot unplug it with the tractor running as it is under the fuel tank, between the grill and engine. If it is bad, can I use one of the newer small regulators in place of it?
#26 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 30, 2015 - 06:22 AM
I bought the actuator from Tom pictured above. It got here yesterday. Now to get it mounted. Have to do some noodling on it as it is shorter than the 'stock' one when closed. The original was right at 14". This one measures around 10-3/8". I either have to make an extension or move the mount location. Plus figuring out the wiring as I have 3 wires going down, but only 2 on this actuator. I know which 2 (out of the 3) are for up/down.
#27 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 30, 2015 - 11:50 AM
I got the new switch today. Wasn't expecting that until early next week. Not sure what will be done today. It's chilly and I would like to get the box project finished up. May see moisture most of the weekend.
#28 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 30, 2015 - 05:58 PM
I got time to play with the actuator & switch. The actuator is a 4" stroke which should work for the tiller lift. Took the time to get the switch wiring figured as it does not work with the Jake wiring & switch. Started figuring out how to mount it. The Jake mount will not work for 2 reasons. 1- it is 3-5/8" shorter than the original. 2- it is wider (3") than what room is there (2-1/4"). Got an idea working and found some metal to make it from. Here's a few pics:
This is what I have to replace.
#29 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted February 01, 2015 - 04:31 PM
Went out and braved the cold and wind for a little bit today. I needed to rotate the base mount 90° as the hole would be vertical and should be horizontal for my application. Had to take the whole thing apart, but got it done. Hands were nearly frozen, so I came back in. Worked on the mount drawing a bit. Have a good Idea of what is needed now. Later this week it will warm some so maybe I can get that built, mount the actuator, and get it wired in.
#30 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted February 02, 2015 - 12:43 PM
I may go back out for a bit this afternoon. Not much wind, but it's only 28° right now. Tomorrow it should get up to about 50°+ again. I have most all of it figured out, just need warmth to get this done. I got out and gathered wire, connectors, & shrink tube a while ago. Found a 2 wire connector for the actuator. I am going to run all new wiring, even to the switch. The power comes off the lead to the PTO switch. I might run a new larger wire for that just to be safe. I will take pics, so keep checking in.
Also tagged with one or more of these keywords: jacobsen attachments, jacobsen tiller, super chief 1450 tiller
