Air compressor: Factory or home made?
18 replies to this topic
#16 Alc ONLINE
  • 6,885 Thanks
  • 7,461 posts
Posted January 09, 2015 - 06:35 AM
That would make a nice little show piece to tow with a GT at shows :thumbs:  How may psi did something like that run ? That might be the only thing that would make me nervous if it was set higher then that tank/tubes was designed for . Really cool !!!
  • karel said thank you
#17 karel OFFLINE
karel
  • 2,081 Thanks
  • 1,387 posts
Posted January 09, 2015 - 11:06 AM
aaahhh.... I was wanting it to spin a wrench. i'll have to add a tank.
#18 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted January 09, 2015 - 01:39 PM
  Looks like a nice unit complete w/ unloader valve it appears. Is that a hole drilled in the air "tank" near the pump flywheel? Don't see a press gauge, so you need to find what it's running at. You could pull the pump head to get cyl dimensions and figure CFM at whatever the RPM is.
                                                          Mike
Edited by ol' stonebreaker, January 09, 2015 - 01:49 PM.
  • Sawdust and karel have said thanks
#19 karel OFFLINE
karel
  • 2,081 Thanks
  • 1,387 posts
Posted January 10, 2015 - 07:06 AM
the hole at the rear near the pump flywwheel is threaded. there is no pressure guage,like you said mike i'll have to measure the piston and figure what the output of the pump is, because I have no idea.
  • Sawdust said thank you
