Something followed me home ...
bolens 1220 restored
31 replies to this topic
#16 Deerlope OFFLINE
Deerlope
  • 819 Thanks
  • 483 posts
Posted January 08, 2015 - 08:36 PM
Sweet looking machine.
#17 T Guiles OFFLINE
T Guiles
  • 956 Thanks
  • 749 posts
Posted January 08, 2015 - 11:36 PM
Great score, hope you get it fired soon.
#18 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 09, 2015 - 01:45 AM
That's look like a sound buy to me. Good luck with getting the engine fired up.
#19 stanz OFFLINE
stanz
  • 73 Thanks
  • 70 posts
Posted January 09, 2015 - 02:11 PM
Garage is getting crowded, 1220 with Briggs 16HP boxer engine on right, new 1220 on left
#20 Bolens800uk OFFLINE
Bolens800uk
  • 2663 Thanks
  • 1480 posts
Posted January 09, 2015 - 03:41 PM
I know that feeling only too well. I just have to restructure my garage space again.
#21 stanz OFFLINE
stanz
  • 73 Thanks
  • 70 posts
Posted January 16, 2015 - 10:52 PM
First things first, it's running now, and really well.
The coil in the new stator checked out bad, less than 400 Ohms.  I swapped the stator, ignition module, and flywheel from my old Tecumseh onto it, pulled the plug and it had spark.
I reassembled the engine, put gas in the tank, squirted some starting fluid in the carb and BOOM!  I had done something I've never done in over 40 years of working on engines ... I forgot to tighten the spark plug.  It blew out of the head and stripped the threads. :wallbanging:   Boy, that was stupid, and it won't happen again.
I pulled the head off the other engine, cleaned all the carbon off and installed it.
Tightened EVERYTHING and it started right up.  It runs super smooth even at low RPMs. It's running in this picture, no smoke.
Now I gotta figure out the wiring. the PO had hardwired everything without connectors.
Now I have two running tractors, what's the plural of Bolens anyway?
  • OldBuzzard and sacsr have said thanks
#22 Toolfoole OFFLINE
Toolfoole
  • 271 Thanks
  • 145 posts
Posted January 17, 2015 - 08:24 AM
Congrats on a job well done. :good_job:  Don't be too hard on yourself about the loose plug, I think we've all done things like that. A friend of mine once rebuilt a lawnmower engine only to find out later that it was merely out of gas! :brain_fart:  I've done my share of dumb things, too. Chalk it up to a learning experience.
You can probably salvage that head, if you ever need to, by installing a thread repair insert. Get the Heli-Coil Sav-A-Thread 5334-14 spark plug repair kit for about $27.
The plural of Bolens is Bolens' (in print, anyway).
  • stanz said thank you
#23 stanz OFFLINE
stanz
  • 73 Thanks
  • 70 posts
Posted January 17, 2015 - 12:50 PM
Oh, I left that part of yesterday's fiasco out. I bought a "Plug-Saver®" kit and followed the directions:
1) Load the Plug-Saver® tap up with grease to catch the chips from the cutting process, no need to remove the head.
2) Start the tap in the hole by hand and finish with a 3/4" socket.
I never got past #2. It was moving along well until it got a bit hard and then the tap shifted about 20 degrees.  I removed the tap and found a much larger hole with no threads?  The spark plug in the old cast iron Tecumseh is NOT over the piston!!!  The Plug-Saver® tap is longer than a regular tap due to the starter threads. It bottomed out and shredded the threads it had just cut.  It's a paperweight now unless I switch it to a 18mm plug. :mad2:
#24 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted January 17, 2015 - 08:18 PM
OUCH.!!!    Sorry to here that.. sounded like everything was going so well...!!
#25 stanz OFFLINE
stanz
  • 73 Thanks
  • 70 posts
Posted January 17, 2015 - 09:15 PM
It's all good now. I just need a battery, seat, plow, and chains to complete the setup.
#26 adamjd200 OFFLINE
adamjd200
  • 2132 Thanks
  • 2233 posts
Posted January 17, 2015 - 10:21 PM
I watched a guy start an Onan gen-set at an auction last year and the spark plug turned torpedo, scares the crap out of you doesn't it? :D
#27 stanz OFFLINE
stanz
  • 73 Thanks
  • 70 posts
Posted January 18, 2015 - 03:57 PM
It sounded just like a gunshot, yeah it woke me up.
#28 stanz OFFLINE
stanz
  • 73 Thanks
  • 70 posts
Posted January 31, 2015 - 02:56 AM
Battery installed, wiring sorted, fuel leak stopped, Allis Chalmers/Simplicity plow modified and installed.
Almost ready for work!  The plow is a tight fit on the right side, but it should be okay, see pictures.
The left hand spindle has a lot of play, about 15 degrees when steering.  It feels like the hole for the pin is worn in the spindle, I'll have to remove it to check.
Then
i mount chains and weight box and it's good to go.
Plow mounted
Closeup:
  • LPBolens, sacsr and Rock farmer have said thanks
#29 stanz OFFLINE
stanz
  • 73 Thanks
  • 70 posts
Posted February 01, 2015 - 07:11 PM
The spindle was bored to 5/16" and the steering arm was 1/4" with a 1/4" bolt through it.  I bored out the steering arm to 5/16", slid in a 5/16" bolt and the steering is fine now.
Chains installed, weight box mounted, I started it up, put it in gear and nothing!  The drive belt idler spring wasn't hooked up and the clutch nut wasn't tight.  Once that was sorted it worked fine.  I still need a seat and the linkage for the plow is a bit wonky.
#30 HJR OFFLINE
HJR
  • 44 Thanks
  • 54 posts
Posted February 01, 2015 - 10:01 PM
Nice looking tractor there! :thumbs:
