Good Pulling Tires?
4 replies to this topic
#1 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,426 Thanks
  • 1,857 posts
Posted January 06, 2015 - 09:14 PM
Would these tires be good for stock fun pulls? Nanco Wooly Boogers 25x10-12. Thanks I want to use them on my AC B-212.
#2 VintageIronCollector OFFLINE
  • 1,426 Thanks
  • 1,857 posts
Posted January 06, 2015 - 09:15 PM
Said they hold 420lbs each.
#3 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted January 06, 2015 - 11:51 PM
I'd bet they would do pretty well as long as they are still able to flex a little, I bought one late last year for the kids to pull but we didn't get it out in time. Let me know how they work for you
#4 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted January 07, 2015 - 04:53 AM
I think they would do pretty good. Keep the air pressure down to you get as much surface area of the tire against the ground. They have a decent tread pattern.
#5 Dieselcubmike OFFLINE
Dieselcubmike
  • 1,335 Thanks
  • 1,520 posts
Posted January 07, 2015 - 10:37 PM
What size tire are you allowed to run? I would say no because of how the tire lug curves your not having a good contact point with the ground. Actual lug tires like Carlisle would work better because when the tire digs down it helps push the dirt off to the side instead of in front of the pan. It would be good for riding around with but thats all i would do with it. What pull are you talking about? transfer sled style or dead weight? I would recommend the old  Carlisle lug tires or even their super lugs since your not looking for pro tires. Ive always had good luck with those.
  • VintageIronCollector said thank you
