How to clean and adjust Carburetor?
3 replies to this topic
#1 MTD Tradesman OFFLINE
MTD Tradesman
  • 3 posts
Posted March 03, 2011 - 05:42 PM
Hi there, I am new to GTT and i'm wondering how do I clean a Kohler Carburetur off a John Deere 214? What are it's factory specifications to set it back to? Where can I get cleaner locally (lowes, home depot, ace, tractor supply, etc.)? Thanks and have a great day!
#2 JoshBrown OFFLINE
  • 20 Thanks
  • 277 posts
Posted March 03, 2011 - 06:42 PM
Any auto parts store (advance, NAPA, autozone) will have carb cleaner. It is in a spray can like wd-40. Basically you take the carb off the engine and totally disassemble and clean everything. Be careful when taking apart not to lose any small parts and there are little paper gaskets in the carb be careful not to tear them if you do the carb will leak gas and you will have to get more. Take a small piece of wire and run through all the jets to open up in case they are clogged with rust gunk ect. spray all passageways with the carb cleaner and basically just clean everything out. It helps to take lots of pictures of how all the linkages are hooked up and how everything is put together before you take it apart so you can see how it goes back together. It's really not hard and it's the only way you will learn. Worse case scenario you have to take all the pieces to a small engine mechanic and have him reassemble. If you don't try you are going to have to take it to a mechanic anyway. Good luck.
  • Rickski and MTD Tradesman have said thanks
#3 Texas Deere and Horse ONLINE
  • 14,859 Thanks
  • 15,510 posts
Posted March 03, 2011 - 07:25 PM
You will probably want to get a carb kit for this also. Usually you need to replace the bowl gasket.
  • MTD Tradesman said thank you
#4 Tmo OFFLINE
  • 360 Thanks
  • 486 posts
Posted March 03, 2011 - 08:45 PM
Is this the Kohler (Carter) carburetor or the Walbro carburetor? If it's a Kohler (Carter) carburetor, here is a good tutorial on cleaning and rebuilding one: http://mgonitzke.net...arb_rebuild.pdf
  • Rickski, lyall, MTD Tradesman and 1 other said thanks
