Vote for Tractor of the Month
Hyd h2 control linkage on 314
5 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 05, 2015 - 08:49 PM
Has anyone had any experiencce installing h2 hyd from 317 to a 314 ? I'm having trouble with bottom control linkage hitting frame when I try to hook it up . I know I've got everything according to JD parts picture .
Any help would surely be appreciated .
larryd
#2 truck21 OFFLINE
truck21
  • 447 Thanks
  • 257 posts
Posted January 05, 2015 - 09:00 PM
  Hi Larry,
    I just did that a couple of months ago and mine went real smooth. Do you have any pix of your linkage? I think when I did mine I had to rotate my linkage 180 degrees.
     Don
  • Trav1s said thank you
#3 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 05, 2015 - 09:16 PM
Hello Don ,
I tried that but it doesn't let lever move much . It seems like the control arm is to far inside the frame. I 'll try to take  a picture with my iphone .
#4 truck21 OFFLINE
truck21
  • 447 Thanks
  • 257 posts
Posted January 05, 2015 - 09:37 PM
 Larry, do you have the arms that the linkage hooks to turned the right way and adjusted as close to the end of the shaft as possible?
  The first time I put mine together I had the arms wrong. Did you do duel brakes also ?
     Don
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 05, 2015 - 10:40 PM
yes they are and yes I have dual brakes
larryd
#6 JDBrian OFFLINE
  • 9,591 Thanks
Posted January 06, 2015 - 07:25 AM
Do you have the parts diagram for a 317. It shows the correct orientation for the levers and the short arm that attaches to the lever shaft. There are also spacers shown that need to be in the correct places. I found the diagram less helpful with getting the linkage parts assembled correctly for the 2 levers.
