Magneton Alternator Wiring
2 replies to this topic
#1 Alc OFFLINE
  • 6,745 Thanks
  • 7,397 posts
Posted January 05, 2015 - 07:44 PM
My boss is working on a Leroi Air Compressor run by a John Deere diesel ( I'm guessing inport ) mid eighties he said . At some point someone installed a Magneton Type 443113516765 alternator . Now the problem is the connector/wiring was hacked .  Does anyone have a wiring diagram for this alternator ?  Has B1, W1  , D1  labled on the terminals .  Thanks Al
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted January 05, 2015 - 11:31 PM
Does it have a normal tractor "T" connector with two little spade terminals and then two studs (Asian and American style), or is it the European style that I have never understood perfectly?
You can call Chestnut Hill Auto Electric, talk to Harvey.  That man is sharper than a tack on anything related to starters or alternators.  Tell him I sent you.
Phone number (717) 445-4516
Ben W.
#3 Alc OFFLINE
  • 6,745 Thanks
  • 7,397 posts
Posted January 06, 2015 - 06:19 AM
Thanks Ben I will have to talk more with my boss , to see what he's working with . After posting this I was thinking he's still might need to know the color code of the harness . I would think there would be a pretty big wire to charge the battery but from the little info I found one is used for a tach and the other the field wire .
