Wanted
Briggs and Stratton 6s wanted
27 replies to this topic
#16 MH81 OFFLINE
Posted January 05, 2015 - 09:52 PM
http://gardentractor...-model-6-motor/
  • adamjd200 said thank you
#17 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
its a shame we are all so far aprt, as I have one of these sitting on the shelf with the rope start also. You do relies that you can change the rope start over to a recoil one, providing you have the recoil unit and it drive parts.
Post a pic of yours as I would like to see it, don't think shipping would be any worse from IA than MN.  Color/patina is a consideration here too as I am leaving the unit in its original patina, and yes I know you can switch the starters, just might have to rebuild my starter.
#18 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 05, 2015 - 09:55 PM
Different motor, a 6s has a suction carb, see post #1
#19 DougT ONLINE
DougT
    Dog Approved
  • 6,929 Thanks
  • 4,996 posts
Posted January 05, 2015 - 11:23 PM
I would check to be sure. i think the crankshafts are different. You might be able to use it but i think the recoil one has an extended shaft to support the recoil piece that threads on the crank.
  • Lauber1, superaben and adamjd200 have said thanks
#20 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted January 06, 2015 - 11:19 AM
boyscout862, how close are you to that engine?
I don't know, the ad doesn't say what town they are in. Good Luck, Rick
Edited by boyscout862, January 06, 2015 - 12:26 PM.
#21 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted January 06, 2015 - 02:57 PM
yep doug is right I forgot about that stupid part that come through the center. Its the one that always make the squeal when it get dry. My engine is buried in one of the back sheds, and since we just got 8" of snow I wont be going out back for a while to look.
#22 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted January 06, 2015 - 06:19 PM
The guy called and is only 1/2 hour away. I'll go see him later this week. We had a nice conversation. Good Luck, Rick
#23 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 06, 2015 - 06:56 PM
Thanks I owe ya!
#24 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted January 06, 2015 - 07:12 PM
Thanks I owe ya!
Do you want me to buy it for you? I was going to evaluate it for what is stuck. I would expect the rings to be stuck but it might be the flywheel. If the rings are stuck, there will be a slight movement of the crank.
Edited by boyscout862, January 06, 2015 - 07:14 PM.
#25 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 06, 2015 - 09:43 PM
Check it out, if it turns out to be just the flywheel buy it and let me know, thanks Adam.
#26 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 15, 2015 - 02:58 PM
Did you get it? The ad is gone.
#27 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted January 15, 2015 - 03:09 PM
No, I haven't felt up to going. Between the bad weather and my gut problems I don't go anywhere. Sorry, Good Luck, Rick
#28 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted January 15, 2015 - 05:43 PM
No problem, thanks.
