Converting a zero turn mower deck to be used on a garden tractor
24 replies to this topic
#1 vicamen18 OFFLINE
vicamen18
  • 10 Thanks
  • 14 posts
Posted January 04, 2015 - 04:44 PM
I'm new to this forum and appreciate the opportunity to participate. I am a dubber...meaning I dub around with my three John Deere mowers/ tractors. I have a 2006 John Deere 115 (riding mower), a 1978-1984 John Deere 212/214 (3 tractors made into 1), and now a John Deere Sabre 2354 minus the deck. This is a fun hobby and I enjoy it.
I have not been successful in locating a 54" deck for the Sabre. I did find a 50" craftsman zero turn deck. Other than the obvious mounting, is there any show stopper that may make this a bad idea to pursue? My tractor has a vertical shaft engine with electric pto and manual lift.
Things that are different (by eye) are: mounts, configuration of spindles, possible manual pto linkage, shape of deck.
Has anyone converted a zero turn mower deck to a "regular tractor" deck before? Unfortunately, the site will not enable me to attach a picture of the deck.
Thanks for your input.
Kevin
#2 Alc ONLINE
  • 7,226 Thanks
  • 7,578 posts
Posted January 04, 2015 - 05:10 PM
Welcome to GTTalk ! Can't help you will your deck question but I'm sure someone will have some ideas for you
  • vicamen18 said thank you
#3 KC9KAS ONLINE
KC9KAS
  • 5,464 Thanks
  • 4,722 posts
Posted January 04, 2015 - 05:25 PM
:welcometogttalk:
#4 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 04, 2015 - 05:31 PM
Welcome to the forum, fellow Virginian!
Ben W.
#5 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted January 04, 2015 - 06:54 PM
:wave: Welcome to the forum! You're soon to find out the folks here like pics, so check out the link in my signature for uploading them. And charge up the camera batteries!
#6 HDWildBill OFFLINE
  • 8,984 Thanks
Posted January 04, 2015 - 07:17 PM
Hi Kevin, Welcome to GTtalk.  The first thing that came to my mind other then what you posted is how the deck fits under the tractor.  Will it limit turn radius, when it is aligned with the pto will if clear tires.  I think that would be the first thing I would be concerned about.  I haven't converted a deck over but I do work on GT's and Zero turns and Zero turns tend to have a more fuller deck design.
#7 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,107 Thanks
  • 10,179 posts
Posted January 04, 2015 - 07:23 PM
Maybe you could add more parts and make it a ztr tractor.
#8 vicamen18 OFFLINE
vicamen18
  • 10 Thanks
  • 14 posts
Posted January 04, 2015 - 08:03 PM
Thanks for insight. I assumed that because it could take a 54" deck that a smaller deck would not be a problem; but then, when I was reminded that it was a different shape, that is probably the kicker. I did follow the instructions on loading and have attached the picture of the zero turn deck. Thanks for the help.
#9 vicamen18 OFFLINE
vicamen18
  • 10 Thanks
  • 14 posts
Posted January 04, 2015 - 08:06 PM
It helps when you press "attach this file";)
  • TomLGT195 said thank you
#10 Gabriel OFFLINE
Gabriel
  • 1,447 Thanks
  • 1,862 posts
Posted January 04, 2015 - 08:31 PM
WELCOME to GTTalk!
#11 Cat385B OFFLINE
    HAZMAT CAT
  • 14,370 Thanks
  • 10,139 posts
Posted January 04, 2015 - 10:02 PM
I don't know the wheelbase measurement of a JD Sabre, or the length of the Craftsman deck pictured. But I see no reason why that deck can't be made to work under the JD.  You're just going to have to adapt the JD lift arms to those two pins on that Craftsman deck, and figure out a different draft arm set up to hook to the front or axle mount on the JD. You might be able to flip that tensioner pulley arm around 180° and use it for the drive belt coming from the front, even.
#12 toppop52 OFFLINE
toppop52
  • 5,538 Thanks
  • 4,901 posts
Posted January 05, 2015 - 07:28 AM
If you decide not to use it, I may be interested in buying it, my Craftsman zero turn, which by the way are made by Simplicity in those years, has a well worn 44" deck and I mow 1.5 acres and would love that 50" deck.
#13 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted January 05, 2015 - 09:21 AM
:welcometogttalk:
#14 vicamen18 OFFLINE
vicamen18
  • 10 Thanks
  • 14 posts
Posted January 05, 2015 - 10:46 AM
Good morning, All. Thanks for the warm welcomes and ideas. I thought I would upload, side-by-side, the deck in question and the deck the tractor was designed to carry (54" Scotts deck is pictured). The pictures are not the same size or aspect; meaning, the side comparison is for shape only at this point. have not made any measurements; for that fact, I haven't contacted the owner because I didnt want to waste his time about a potential project. All of your input is great.
TOPPOP52- I have not set up my profile yet and am still learning how to use this site. Does our membership automatically set up a GTt email to pm? I will gladly send you the contact info.
This is a good thread! Now...if I could only find a John Deere Sabre, Scotts, or GT275, G100 and I could have used that deck!
  • toppop52 said thank you
#15 HDWildBill OFFLINE
  • 8,984 Thanks
Posted January 05, 2015 - 01:36 PM
When you get a PM you should get a notification to the Email address you used when you set up your account.
The Scott's deck looks very much like the Yamaha deck.  Unfortunately a Yamaha deck would probably be harder to find then the Scott's.
