John Deere Blade on Bolens HT-23
8 replies to this topic
#1 BTS ONLINE
BTS
    Make Stuff Up
  • 3,320 Thanks
  • 1,995 posts
Posted January 03, 2015 - 11:40 PM
Well, I have a 52" blade off of a John Deere 140-H3, I have had it for several years, but I don't need it because my 140 has a loader. I have decided to put it on my Bolens HT-23, since it only has a mower deck, it has nothing to do in the winter.
Anyway, I got part of the mount built today, hoping to finish it tomorrow, but that's depending on how much snow we get tonight on if I can get to my neighbors shed to work on it. I wish it was already done so I could push snow with it but I guess I'll use a shovel till I get it done lol.
Also got a picture of the Bolens posing next the my bug that's being rebuilt and I also got a picture of the cat warming up by the heater :thumbs:
  • Bud and A.C.T. have said thanks
#2 superaben OFFLINE
superaben
    Con Man
  • 7,665 Thanks
  • 5,677 posts
Posted January 04, 2015 - 12:02 AM
That's just like Cat, taking the best spot in the house.  I didn't know you had a personal visit from him, though.
Ben W.
  • JDBrian and BTS have said thanks
#3 JDBrian OFFLINE
  • 9,594 Thanks
Posted January 04, 2015 - 06:53 AM
Ben W.
Yes, It's all part of his meet the members and Meowy Christmas tour.
  • KennyP and superaben have said thanks
#4 JDBrian OFFLINE
  • 9,594 Thanks
Posted January 04, 2015 - 06:56 AM
How are you going to mount the blade to the bar you have added to the front of the tractor. The JD's have a front mounting arrangement built into the frame with a lot of metal added to strengthen the area.  The blade puts a lot of stress on the frame when you inevitably run into some solid object.
#5 BTS ONLINE
BTS
    Make Stuff Up
  • 3,320 Thanks
  • 1,995 posts
Posted January 04, 2015 - 11:06 AM
I have cut off the lower mounts on my John Deere 140. The 140 doesn't have a use for them because I am building it into a crawler and it now sits to high on the tracks to use the blade or any other attachments on the front mount. (it also has a loader) . Anyway, I am going to use those mounts and then build the upper part of the mount (that is the 140 frame) and then weld it all on the mount I already have built. I am going to put more braces on and it should be strong enough.
I hope all of that makes since :thumbs:
Edited by BTS, January 04, 2015 - 11:10 AM.
#6 BTS ONLINE
BTS
    Make Stuff Up
  • 3,320 Thanks
  • 1,995 posts
Posted January 04, 2015 - 08:03 PM
Got the mount finished, I need to get some hydraulic hoses and then I can go test it. Once it is working I will clean it up and paint it.
#7 BTS ONLINE
BTS
    Make Stuff Up
  • 3,320 Thanks
  • 1,995 posts
Posted January 07, 2015 - 07:52 PM
Finally finished the bracing on the quick attach mount. Although the blade mount is in the way of 1 hydraulic port so the blade will raise but it will not lower. If I lower the hydraulic ports maybe a inch then I should have the room to plug the second line in.
Anyway, once that is fixed it should be ready to go!. I stood on the blade when it was raised up and nothing bent or broke :thumbs:.
Now I can mount any John Deere front attachments which will be nice since there is a lot John Deere equipment around here and there is no Bolens to be found.
#8 KennyP OFFLINE
  • 32,718 Thanks
  • 42,324 posts
Posted January 08, 2015 - 05:59 AM
Glad you have that working for you.
  • BTS said thank you
#9 BTS ONLINE
BTS
    Make Stuff Up
  • 3,320 Thanks
  • 1,995 posts
Posted January 09, 2015 - 12:45 AM
Got a cutting edge welded on today!
