Super chief 1450 question
10 replies to this topic
#1 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted January 03, 2015 - 10:25 PM
Can anyone post a picture of the throttle cable and how it mounts to the carb? I can't seem to remember how it goes on as I have had it apart for a while
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 04, 2015 - 01:32 AM
The only cable to the carb should be your choke.
The throttle cable will go to a pivoting bracket that bolts to the block with one screw ( near the fuel pump).
From there a spring goes to the bottom of the governor arm. Then there is a solid rod that will go from the top of the governor arm over to the top of the carb.
There are a few minor differences in how they mount but this is the basic set up.
If you can take a picture of the Carb side of your engine and possibly the pieces you have, that would make it easier to explain.
Good luck, Chris
#3 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 04, 2015 - 04:44 AM
I don't have any pics of mine. Can maybe get something later today. I think Chris is right, but would have to look to be sure. And it's cold and dark out there!
#4 Rock farmer ONLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted January 04, 2015 - 11:12 AM
It should go like this;
Joe
#5 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 04, 2015 - 11:37 AM
Just out of curiosity here, WHICH 1450 are we talking about? There are the older ones, the 'open side' tube frames, and the 'closed side' tube frames.
I'm thinking from the title, the Super chief is the older model with the crank across the frame.
#6 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 04, 2015 - 11:53 AM
Here's a couple pics from my Super Chief. Looks light the battery cable got in the way on the first pic. Might be better to try another one this afternoon.
The red arrow is the throttle cable.
#7 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted January 04, 2015 - 12:11 PM
It's a 1970 model
#8 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
Posted January 04, 2015 - 12:26 PM
That would be more like the pics I posted. I'll see if I can get a better one here in a bit. Wind chill is about 6° right now!
#9 Rock farmer ONLINE
Rock farmer
  • 1,197 Thanks
  • 1,232 posts
Posted January 04, 2015 - 01:47 PM
My bad!
My first picture is a closed side.
This one is my open side Ford LGT 125;
Joe
#10 KennyP ONLINE
  • 37,546 Thanks
  • 45,533 posts
See if this helps!
#11 Unstuck747 OFFLINE
Unstuck747
  • 49 Thanks
  • 63 posts
Posted January 04, 2015 - 11:15 PM
Got it figured out today thanks for all the help. Now just to get the engine running!
