DIY Insulated Clamps
11 replies to this topic
#1 Sawdust OFFLINE
Sawdust
  • 6,220 Thanks
  • 3,581 posts
Posted January 03, 2015 - 07:59 PM
I've been re wiring my tractor & needed a couple of clamps. It's been raining hard all day. I had my ipod playing bluegrass, plenty of coffee, & things were going great so I didn't want to leave the garage. This is what I came up with.
I cut a piece of plumbers strap 3 3/8" long & a piece of 1/2" diameter heat shrink tubing 1 3/4" long. Most of this strap is cut the same but you may have to make a few adjustments in the length. I also drilled out the 4th large hole a 1/4" with a step drill. This will meet up with the top hole for the bolt. Make a 90 degree bend between the top large hole & the small hole as indicated.
Slide the tubing as shown.
Hold the top bend area against a 1/2" rod or what ever you have then wrap tightly around the rod. If all goes well the two 1/4" holes should line up. Once this is done shrink the tubing. I rounded off the corners to give it a professional look  :D
The first clamp I used I needed it where an engine shroud bolt was very hard to put in earlier because of lining up the sheet metal. I didn't want to back it all the way out so I clipped off the area between the holes so I could just slide it into place. Hope this comes in handy for someone & thanks for looking.
  • olcowhand, Bud, limebuzz and 19 others have said thanks
#2 TAHOE ONLINE
TAHOE
  • 8,338 Thanks
  • 5,820 posts
Posted January 03, 2015 - 08:03 PM
Well aren't you the ingenious one today  :thumbs:
Looks great.
I used the shrink wrap on a battery hold down clamp to insulate it, I love that stuff.
  • limebuzz, Sawdust and Gabriel have said thanks
#3 KC9KAS OFFLINE
KC9KAS
  • 5,482 Thanks
  • 4,736 posts
Posted January 03, 2015 - 08:05 PM
Great idea...use what you have handy!!
  • Sawdust and Gabriel have said thanks
#4 KennyP ONLINE
  • 41,519 Thanks
  • 47,425 posts
Posted January 03, 2015 - 08:17 PM
Great idea! Thanks for sharing!
#5 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 03, 2015 - 09:15 PM
Great work, Jim.
See what good listening to bluegrass does for you, all you rock fans?
Ben W.
#6 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,089 Thanks
  • 1,284 posts
Posted January 03, 2015 - 09:29 PM
Jim,
You the man. Nice work.
#7 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted January 03, 2015 - 11:58 PM
Nothing works like a "P" clamp!
  • Sawdust said thank you
#8 Kmac1 OFFLINE
Kmac1
  • 522 Thanks
  • 221 posts
Posted January 04, 2015 - 04:27 AM
great idea, wonder if there should be a section for DIY ideas, tools and tricks
  • HDWildBill, Sawdust and Gabriel have said thanks
#9 glgrumpy OFFLINE
  • 8,849 Thanks
  • 8,036 posts
Posted January 04, 2015 - 11:17 AM
Sorry, I'ld be over to ACE not 1/2 mile away and good selection and back. More time for something else then. These little things take to much time for the effort anymore. AND, I wouldn't have had all that parts around to do it anyway and STILL need to go to Ace to get that and all at a cost way more than just buying the thing finished.  By the way......Those are neatly made!  And, I listen to Jazz and Blues or NPR in my shop. Just my waste of bandwidth for today, seeya!
#10 Gabriel OFFLINE
Gabriel
  • 1,449 Thanks
  • 1,863 posts
Posted January 04, 2015 - 08:56 PM
Nice work, Jim! Thanks for sharing!
Edited by Gabriel, January 04, 2015 - 08:56 PM.
#11 HDWildBill OFFLINE
  • 8,985 Thanks
Posted January 05, 2015 - 11:01 AM
That really is a great idea Jim! That is using your knogen for something besides a hat rack. Not only if you need one in a pinch but if you need a custom size.
That is a pretty good idea. :thumbs:
#12 Bill 76 OFFLINE
Bill 76
  • 2,015 Thanks
  • 1,208 posts
Posted January 07, 2015 - 12:55 AM
Great idea,thanks for the tip.I got a shoe box of them adell clamps but I never got the right size,thanks again.
