Tecumseh Oh160 tapered crank kohler m12 swap
tecumseh oh160 kohler m12 k301 generator tapered crankshaft
3 replies to this topic
#1 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 03, 2015 - 02:02 PM
Hello everyone been a whole since I Have posted I picked up a miller engine drive welder that had a Tecumseh Oh160 that was sized full of rust and I wasn't sure about it ever running again after some sea foam penetrating oil and a hammer along with a wire brush I got it to run it ran alright till it got hot and started smoking and knocking I hate Tecumseh's so I'm not using that anymore I picked up a low hour magnum 12 of a insulation truck starts and runs great my issure Is that the Tecumseh has a tapered crank I have a spare crankshaft from a k341 however I'm not positive they are the same (took a crank once to have it machined and turned out the length was different does any one have the crankshaft charts for both the Tecumseh and the kohler a for me to take to the machine shop? Or does someone happen to have a tapered crankshaft to fit my magnum In the pictures there is full model/serial numbers
Any help would be apreacited
Thanks
Ty
Edited by 8tyman8, January 03, 2015 - 02:04 PM.
#2 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted January 03, 2015 - 02:08 PM
#3 drbish ONLINE
drbish
    Collecter
  • 1,496 Thanks
  • 1,316 posts
Posted January 03, 2015 - 03:41 PM
For the Tecumseh,your crank shows up as part number 33423b,
In group 14,page 29, fig 10 are your dimensions
Attached File  oh160cr.PDF   809.97KB   89 downloads
here is your model
http://www.tecumsehp...H1201170151E-EN
Edited by drbish, January 03, 2015 - 03:42 PM.
#4 EricFromPa OFFLINE
EricFromPa
  • 3,224 Thanks
  • 2,907 posts
Posted January 03, 2015 - 11:09 PM
Kohler Crankshaft Reference manual here. Go to pages 32-37 for K301/M12 cranks.
http://gardentractor...ft-reference-2/
A GOOD machine shop can turn down your crank easily or even make an adapter for the M12 crank.Take all 3 cranks in with you and see what they say.
Also tagged with one or more of these keywords: tecumseh oh160, kohler m12, k301, generator, tapered crankshaft
