Main ground wire
4 replies to this topic
#1 Cadet106 OFFLINE
Cadet106
  • 11 posts
Posted January 02, 2015 - 02:29 PM
I'm trying to rewire my 106 and i need to know where to put the main ground wire and the one that goes up toward the regulator.
#2 CRFarnsworth ONLINE
CRFarnsworth
  • 4,706 Thanks
  • 2,160 posts
Posted January 02, 2015 - 05:46 PM
maybe this will help.  I like to have a good ground to both the engine& the frame/body .  Rick
  • Cadet106 said thank you
#3 Cadet106 OFFLINE
Cadet106
  • 11 posts
Posted January 02, 2015 - 06:46 PM
Does the little wire up front have to touch the regulator?
#4 NUTNDUN OFFLINE
  • 10,340 Thanks
Posted January 02, 2015 - 06:49 PM
As long as it has a common ground through the frame and other metal parts. The wiring diagram is showing them connected because of it being a diagram. If you have a good heavy gauge ground going to the frame is usually enough but like Rick mentioned it is a good practice to also have another ground running to the engine. Even though the engine is usually mounted directly to the frame there are times where it doesn't get a good ground. Whether it would be due to paint, corrosion or dirt.
#5 Cadet106 OFFLINE
Cadet106
  • 11 posts
Posted January 02, 2015 - 07:12 PM
Ok thanks for the input.
