Freeing up a rusted stuck control cable.
8 replies to this topic
#1 IamSherwood OFFLINE
  • 8,390 Thanks
Posted January 02, 2015 - 07:41 AM
I thought I'd share this, as it may be useful to others when dealing
with a seized control cable.
I've been working on a Massey Ferguson 8 hp Hydrostatic MF8H.
The cable from the shift lever to the hydro drive unit was seized.
Tough to get at the shift lever end, so I disconnected it at the drive unit end.
For 3 days, I dripped PB blaster in to it, 3 in 1 oil, acetone/atf mixture, and
applied a bit of heat. It appeared to be seized only in the aluminum tube
at the end, as I could turn the outer casing.
I finally got it to move about 1/4" by holding the clamp on the casing tightly, and
pounding on the end with a hammer. Fine, it moved, but I needed a easier way to
work it back and forth, to work some grease or oil into it. I had an idea on New Years
morning ( that's surprising in itself ), to make a clamp-on, puller/pusher, so I could
get that cable moving. I took all of 15 minutes to drill a few holes in some 1/4" x 1"
flat bar and round up some 1/4" threaded rod. It work like a charm, and once I
got the solid end of the cable out of the tube, I sanded the rust off. It's working
like a new one now.
  • NUTNDUN, DH1, massey driver and 23 others have said thanks
#2 Kmac1 OFFLINE
Kmac1
  • 522 Thanks
  • 221 posts
Posted January 02, 2015 - 07:47 AM
Thanks for sharing, looks like it worked well
  • IamSherwood said thank you
#3 JDBrian OFFLINE
  • 9,601 Thanks
Posted January 02, 2015 - 07:48 AM
Sweet! Will, that is a great idea! I'm sure lots of people have been faced with that same problem and this is a quick and easy solution.
#4 MH81 OFFLINE
Posted January 02, 2015 - 07:51 AM
Nice. That's using your head for something other than a hat rack.
  • IamSherwood and Sawdust have said thanks
#5 KennyP ONLINE
  • 37,408 Thanks
  • 45,457 posts
Posted January 02, 2015 - 08:14 AM
Good idea, Will!
#6 Sawdust OFFLINE
Sawdust
  • 5,562 Thanks
  • 3,335 posts
Posted January 02, 2015 - 10:45 AM
Amazing how & when our minds work to figure something out. Great idea!
#7 massey driver OFFLINE
massey driver
  • 1,400 Thanks
  • 1,569 posts
Posted January 02, 2015 - 11:32 AM
Looks like you gotter done. Amazing what we think about at the most unexpected times. So many times I've struggled with something and then out of the blue it comes to me hey why don't you do it like this,or hey why didn't I think of that sooner.
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted January 02, 2015 - 12:07 PM
That is a great idea Will!  You would make a great homesteader on the last frontier. Oh wait! your already up there! :smilewink:  :poke:
#9 superspeedex OFFLINE
superspeedex
    gttalk enthusiast
  • 851 Thanks
  • 959 posts
Posted January 02, 2015 - 04:11 PM
that took you all year!
Edited by superspeedex, January 02, 2015 - 04:11 PM.
