gas tank reman
7 replies to this topic
#1 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 01, 2015 - 09:45 PM
   I know this is not gt related but I figured some of you guys may be able to pick up a few tips on here, I had to replace the tank on my stationary engine. started by mapping the entire tank out on paper so I knew where things go when I need to reassemblegas tank 003.JPG , traced out the tank shape and cut the top and bottom sections outgas tank 004.JPG .  once I was positive I had all good template and dimensions I cut the old tank apart, I needed the fitting for the new tank. gas tank 012.JPG
    be careful cutting into an old tank you never know what you will find, I found two baffles and the fuel fitting had a flange on the backgas tank 008.JPG .  removed all the old fittings and brackets to re-use them on the new tank.  tack welded the fuel inlet fittings into the inside of the tankgas tank 015.JPG , then made the baffles and welded them to the top cover.  I drilled 1/4" holed in the tank where the baffles will go so I can spot weld them in place, easier and looks cleanergas tank 025.JPG .  put the side of the tank on starting on the flat section and wrapping it around the tank to assure the correct shapegas tank 021.JPG , tack as you go every 2" or so.  put the top section on the tank using the same procedure.
     once that was done I started to weld it together, start between the tacks and weld toward a tack, keep going in the same direction all the way around using 1/2" long welds, keep moving and don't put to much weld on to keep the warpage downgas tank 029.JPG .
   with the tank welded together and cleaned I lead soldered around the outside of the fittings to seal it up goodgas tank 034.JPG and a quick coat of paint later I was donegas tank 038.JPG
  • MH81, Alc, dthomp17 and 10 others have said thanks
#2 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted January 01, 2015 - 09:56 PM
Nice job Pete. I have to remove the tank from my Mighty Mite hood and see if needs to be replaced. I'll probably need one made if it's shot.
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted January 01, 2015 - 10:50 PM
What engine did that go on?
Looks like it turned out great...
Ben W.
#4 Sawdust ONLINE
Sawdust
  • 5,644 Thanks
  • 3,361 posts
Posted January 01, 2015 - 11:19 PM
Nice job & a good tutorial to follow.
#5 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted January 02, 2015 - 01:00 AM
The tank on the M-M is just a  Briggs tank.
Ben W.
That was the tank for the International LA engine he got the other day.
  • superaben and classic have said thanks
#6 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 02, 2015 - 06:23 AM
   doug t has it correct, the tank was for my IH La engine I picked up recently.  it did come out really well but I still cant get the ^#$*(^#!&#$* engine to start.  going to flat belt it to another motor today and get it running.  I thought maybe someone could pick up a few tips on this hopefully it helps out.
        Pete
#7 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted January 02, 2015 - 09:22 AM
Very nice job making a new fuel tank.
Did you use the PBR cans to make the tank? :poke:  :bigrofl:
#8 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted January 02, 2015 - 09:33 PM
Oh, stop showing off your knowledge of what a daggone gas tank goes to... gee... :rolling: :rolling: :rolling:
You do know your engines. :thumbs:
Ben W.
