Jack shaft reduction on Cub Cadet?
7 replies to this topic
#1 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted January 01, 2015 - 02:38 PM
With the price of OEM Cub Cadet gear reducers up over $250 has anyone that just needed slower due to taller tires used a jack shaft setup to achieve reduction. There is plenty of room and if a sprocket is roll pinned to the front input of the transmission. And the same to the middle roll pin position of the driveshaft (adding a support bearing on the tail of the driveshaft). And then mount a jack shaft with more sprockets. Looking to achieve about 2:1 or even 3:1 reduction over all. I don't ever need faster, my property is an obstacle course and 2nd gear is already too quick to use with my 25x10-12s. I looked at the transmission cut away and the input shaft already has support.
#2 case442 OFFLINE
case442
  • 694 Thanks
  • 424 posts
Posted January 01, 2015 - 05:28 PM
Hi Casey
Are you describing a creeper gear setup?
Mike
  • wvbuzzmaster said thank you
#3 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted January 01, 2015 - 05:50 PM
Ya, I was describing the creeper assembly in the first sentence. I don't want to spend that much.
#4 Cvans ONLINE
  • 7,129 Thanks
  • 6,305 posts
Posted January 01, 2015 - 07:08 PM
Go for it. Just make sure to take some photos.  :D
#5 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted January 01, 2015 - 07:20 PM
Ya, I think I might aim to get 3:1 overall reduction. I see I have limited space but do believe using sprockets and chain I can get slower easily. I have three gears and 1st is about as fast as I like to drive with 25 inch tall tires. I have a pair of 26 inch tall I would like to run instead but I need to lose some speed first. Definitely going to add plate steel to the top and sides of the tunnel to add some peace of mind if a chain were to fail for any reason. Considering 35 chain though.
#6 EricFromPa ONLINE
EricFromPa
  • 4,005 Thanks
  • 3,265 posts
Posted January 01, 2015 - 07:32 PM
You could change the ring and pinion gears in the rear.
I forget what gear set they used but it might be easier than a jack shaft.
Edit:
Never mind lol
Pinion gear can't be changed.1 Piece gear.
Edited by EricFromPa, January 01, 2015 - 07:44 PM.
#7 case442 OFFLINE
case442
  • 694 Thanks
  • 424 posts
Posted January 01, 2015 - 10:31 PM
Casey,
PM me if you would like. I have a creeper that you may be interested in.
Mike
#8 Cvans ONLINE
  • 7,129 Thanks
  • 6,305 posts
Posted January 02, 2015 - 11:15 AM
Some Cub Cadets can interchange with early Dodge Dart and Plymouth Valiant. I think they had a 6 1/4" ring gear.. Should be 1966 and older. This info is based on a foggy memory so keep that in mind and do your research. In my 66 Cuda I had 3.91 gears and removed 3.23's. I think 3.56's were also available.
