hydro leaks
14 replies to this topic
#1 Lksf250 OFFLINE
Lksf250
  • 7 posts
Posted January 01, 2015 - 11:49 AM
I have a 120 for 25 years. Love it. My hydro leaks about a pint to a tank of gas. I have never been able to find or pinpoint where leak is. Oil runs down from what appears between battery box and ?. I found another120 a few years back. Got it running. Started leaking in a similar place. Any help would be greatly appreciated. I have a ford snow plow mounted and use it often. Leak gets my paved driveway all spotted up.
#2 MH81 OFFLINE
Posted January 01, 2015 - 12:18 PM
:welcome: to GTTalk
I assume you have a Ford tractor?
Hope the guys can help you with your leak.
  • Lksf250 said thank you
#3 KennyP ONLINE
  • 40,195 Thanks
  • 46,801 posts
Posted January 01, 2015 - 12:34 PM
:wave: Welcome to the forum! Which 120 is it? That can make a difference in figuring this out.
#4 KC9KAS ONLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted January 01, 2015 - 04:00 PM
:welcometogttalk: , and :wewantpics:
#5 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted January 01, 2015 - 05:04 PM
To be clear, are you leaking gas, oil or both?
#6 Lksf250 OFFLINE
Lksf250
  • 7 posts
Posted January 01, 2015 - 06:15 PM
Hydraulic oil.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,670 Thanks
  • 5,677 posts
Posted January 01, 2015 - 07:56 PM
I have not owned a 120, so I'm just going to generalize.  Does the leak drip only when the engine is running or all the time?
If it drips when the engine is running only, that tells me it is a pressure leak, and I would look for a bad seal, loose bolt, or a loose hose.  If it leaks all the time, it could still be a seal but more probably a gasket or (worse yet) a crack somewhere.
The best way to find a leak is to get it cleaned up and put it to work and actually see where the problem is coming from.
Ben W.
  • NUTNDUN and Lksf250 have said thanks
#8 FilledTires OFFLINE
FilledTires
  • 225 Thanks
  • 192 posts
Posted January 01, 2015 - 11:09 PM
Ditto what ben said. The first step is to identify the leaking area by cleaning it up, running it, observing, and taking notes and photos.
#9 Lksf250 OFFLINE
Lksf250
  • 7 posts
Posted January 07, 2015 - 11:08 PM
How the heck do you post fotos on this site ??. Any help would be lgt cool. Thx.
#10 Lksf250 OFFLINE
Lksf250
  • 7 posts
Posted January 07, 2015 - 11:10 PM
#11 Lksf250 OFFLINE
Lksf250
  • 7 posts
Posted January 07, 2015 - 11:11 PM
How do I post them. ?? Haven't found a goto button or such
#12 Rock farmer ONLINE
Rock farmer
  • 1,240 Thanks
  • 1,247 posts
Posted January 08, 2015 - 01:00 AM
Check out KennyP's post on this thread.
At the bottom of his post you will find a link!
Welcome to GTTalk!
Joe
#13 KennyP ONLINE
  • 40,195 Thanks
  • 46,801 posts
Posted January 08, 2015 - 04:58 AM
Look at the last line in this post!
#14 Lksf250 OFFLINE
Lksf250
  • 7 posts
Posted January 08, 2015 - 05:20 PM
#15 KennyP ONLINE
  • 40,195 Thanks
  • 46,801 posts
Posted January 08, 2015 - 05:24 PM
The last line reads "Need Pic Help? Try this! Click on the BLUE this.
