Getting the 800 alive once again.
31 replies to this topic
#16 michelle OFFLINE
michelle
    Tractorholic by Marriage
  • 331 Thanks
  • 303 posts
Posted March 14, 2011 - 10:19 PM
And another.
#17 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted March 14, 2011 - 10:23 PM
I caught Adam driving it yesterday.
I look hunched over like Im driving fast, but the tractor is in low 1st...
#18 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted March 15, 2011 - 04:47 AM
Thanks for the pics.
#19 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted March 15, 2011 - 07:22 AM
Glad to see the 800 up and running!!!!
so..... Want to donate those hub caps to me ? :D
#20 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted March 18, 2011 - 09:55 AM
Sorry Brian the hubcaps are keepers. Who am I kidding, the whole tractor is a keeper.
After my first drive down the driveway, Ive got a list of stuff to do. Carb adjustment, clutch adjustment and the generator isnt charging. But it does run and drive at this point.
#21 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted March 18, 2011 - 08:28 PM
Thats going to look great when finished.
Seems like the generators always tend to not work on the Bolens for some reason.
All my Bolens except for 3 dont charge.
#22 Trent Thomson OFFLINE
Trent Thomson
  • 208 Thanks
  • 238 posts
Posted March 29, 2011 - 10:23 PM
Hey there. I guessi'm into the same stuff as you.My 800 burned out the coil under the flywheel. I found a new one and replaced it and the points and condenser, but i still can't get any fire. So all that is left is the flywheel. I have been told there is very little magnetism on the magnets.I was just wondering where you were able to find a flywheel. New or used? Or perhaps someone else out here might have an answer for me. Thanks
#23 Bolens 1000 OFFLINE
  • 17554 Thanks
  • 18863 posts
Posted March 30, 2011 - 07:18 AM
Welcome to GTT.
An easy method that many people have done, is ditch the magneto and go with a 12volt coil. I have done it on all my wisconsins and they run great. Its also alot cheaper to get the coil instead of the magneto assembly.
#24 bread320i OFFLINE
bread320i
  • 614 Thanks
  • 1225 posts
Posted March 30, 2011 - 07:06 PM
Welcome to GTT.
You can also get the 12 volt coils new
#25 Trent Thomson OFFLINE
Trent Thomson
  • 208 Thanks
  • 238 posts
Posted April 05, 2011 - 09:52 PM
Do you nned a different flywheel for this or how is it done?
#26 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 181 Thanks
  • 1009 posts
Posted April 05, 2011 - 10:14 PM
No, same flywheel. Get a switch, a 12v coil and some wire.
Battery + -> Switch -> Pos side of coil
Points/condenser -> Neg side of coil
Plug wire to you know where
  • Trent Thomson said thank you
#27 Trent Thomson OFFLINE
Trent Thomson
  • 208 Thanks
  • 238 posts
Posted April 06, 2011 - 08:30 AM
so is this switch just a regular toggle switch?
#28 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted April 06, 2011 - 09:36 AM
Do you need a hood? I have one that came off one of the early tubeframes, and I have no particular use for it. It is the tapered grill style that I think the 800's had.
#29 Trent Thomson OFFLINE
Trent Thomson
  • 208 Thanks
  • 238 posts
Posted April 06, 2011 - 01:19 PM
would i need a resistor with this setup
#30 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 181 Thanks
  • 1009 posts
Posted April 06, 2011 - 03:18 PM
Well yes you could use a toggle switch or a key switch for battery ignition.
You prolly wont need a resistor but it will say on the coil
