Bolens 1886-01
large frame
23 replies to this topic
#16 Rock farmer OFFLINE
Rock farmer
  • 1540 Thanks
  • 1435 posts
Posted January 03, 2015 - 02:41 PM
Measures about .850 at its smallest diameter and about .875 at its largest diameter.
My HT 20 and HT 23 both have disc brakes at the wheels.
This one has a single disc on the side of the tranny.
Joe
#17 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted January 03, 2015 - 02:49 PM
Its a eaton 12....
If your going to fix this you need to pull the rear end then take the pump out and take it apart.
  • Rock farmer said thank you
#18 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
I would say that shaft is pretty well worn
#19 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted January 03, 2015 - 05:44 PM
The 1886 is a great machine. I hope you get yours going I love mine.
  • blackjackjakexxix and Rock farmer have said thanks
#20 Rock farmer OFFLINE
Rock farmer
  • 1540 Thanks
  • 1435 posts
Posted March 09, 2015 - 06:10 PM
So, the weather has warmed up a bit.
And, I pulled the engine out of this today.
When I bought it, the seller told me he did have it running.
But, when I started removing the drive shaft, I could only turn the engine about 5 degrees.
And it felt really bad!
So I added some oil to the cylinders and let it sit.
Today I found the problem! Bad walnuts! About two dozen packed in tight behind the flywheel!
Turns over nice now. I think it will be a good running engine!
Next step is to remove the rear end.
Joe
#21 Rock farmer OFFLINE
Rock farmer
  • 1540 Thanks
  • 1435 posts
Posted April 11, 2015 - 07:36 PM
Got my input shaft back from my welder / machinest friends;
Can't wait to get it together again!
Joe
  • LPBolens and WrenchinOnIt have said thanks
#22 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted April 11, 2015 - 08:37 PM
So how did they fix? Just weld up the shaft and turn it?
#23 Rock farmer OFFLINE
Rock farmer
  • 1540 Thanks
  • 1435 posts
Posted April 11, 2015 - 09:28 PM
Yea, welded up the shaft, and then turned it.
Insufiencet weld, welded again, and turned again.
Re-cut the key way and and fitted a key.
He left it tight and I hand filed it to fit.
  • WrenchinOnIt said thank you
#24 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted April 11, 2015 - 09:37 PM
Joe
Looks great, hey hang onto those friends, handy guys to have around they do NICE work !
Also tagged with one or more of these keywords: large frame
