Finally Found a 1988 Dodge Ram 50
16 replies to this topic
#16 Kmac1 OFFLINE
Kmac1
  • 522 Thanks
  • 221 posts
Posted January 05, 2015 - 07:15 AM
The 2.6 is a known head failure problem, the heads are expensive and can be scarce. otherwise, decent trucks.
The most common head failure was a crack between the valves, which can be repaired for a fraction the cost of a new or used head.
  • toppop52 said thank you
#17 toppop52 OFFLINE
toppop52
  • 5,530 Thanks
  • 4,898 posts
Posted January 05, 2015 - 07:21 AM
Usually they can be repaired, and for what those heads cost a fraction can still be substantial, but the problem is, they can fail again.  We've sold them 3-4 times and run into multiple failures on several. Mind you this has been years ago now.
