early allis b-10 restoration
90 replies to this topic
#16 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 08, 2015 - 05:21 PM
   started making repairs today, plugging holes and re-drilling them in the linkages to take the slop out of it, blasted the seat pan and front frame so I could fix them both.  the frame was worse than I thought, If I had known it was this bad I would have repaired it sooner.  got it done and got the seat pan welded back up, tomorrow more blasting and grinding to make everything pretty for the paint.  need to fix the hood as well it is pretty beat up.  may even look for a replacement depending on what I find after I blast it.
  • VintageIronCollector, Gabriel and TenPn have said thanks
#17 VintageIronCollector OFFLINE
    Immersed in Tractors
  • 1,424 Thanks
  • 1,856 posts
Posted January 08, 2015 - 05:32 PM
we may have an extra hood but I'm not sure.
#18 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 16, 2015 - 05:01 PM
   Got lots done, most of the stuff is sandblasted and I am going to begin painting tomorrow, more pics to come tomorrow.  most of the repairs are made, I still need to look at the hood, vintageironcollector did you find a hood?   I still need a few more things, left side cover fore sure and tires for sure.  got to get a list going.
  • VintageIronCollector said thank you
#19 VintageIronCollector OFFLINE
  • 1,424 Thanks
  • 1,856 posts
Posted January 16, 2015 - 06:03 PM
ya we got one. its a spare but maybe could sell it
#20 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted January 16, 2015 - 07:36 PM
I have a hood also if needed
#21 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 16, 2015 - 08:45 PM
what's a good hood going for? I will check mine tomorrow and see how bad it is.  thank's fella's
#22 Killer_A-C OFFLINE
Killer_A-C
  • 373 Thanks
  • 542 posts
Posted January 16, 2015 - 08:47 PM
50.00 for mine
#23 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 17, 2015 - 08:50 PM
   been very busy today, got all the parts I have blasted ready for paint primed and the first coat of color on there.  looks really good rite now, I have all the seals ordered for the bgb so I can get that put together next week.  hopefully start to re-assemble this week.  got to order up some new hardware.  need to look thru my parts pile, the front end I have is very badly worn, I know I have a new front axle and think I have the plate it hooks to out there. otherwise I need to repair these.
        Pete
  • TomLGT195, VintageIronCollector and Sawdust have said thanks
#24 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 20, 2015 - 08:12 PM
   Still cleaning parts, got the bgb all cleaned up and ready for paint, now all I need are the seals.  started on the small stuff like the steering gears ect.  looking for ss hardware for putting it back together.  tried my hand at making a side cover, been at it for two days, this one looks ok but I think I can get it closer.  try again tomorrow.
                                                           Pete
#25 VintageIronCollector OFFLINE
  • 1,424 Thanks
  • 1,856 posts
Posted January 20, 2015 - 09:09 PM
                                                           Pete
Ya mean you made that bottom side cover? It looks OEM to me! Great job!
#26 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 20, 2015 - 09:27 PM
    Yes I did make it but it is not quite rite, the corners are to sharp and the divit is to deep, if you look close at the pic you can see it.  I have a new template made and am going to give it a try tomorrow, not sure why I cut this one out and drilled the holes.  not sure what I am going to do with it.
        Pete
#27 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 21, 2015 - 08:47 PM
    Now I am happy, the side panel came out excellent!!!!  I wish I had seen how bad this tractor had been beaten up so bad, I am burning thru all me parts replacing things on this that are hacked or broken.  getting to the bottom of the stack now, hopefully I can start to re-assemble this weekend.
  • TomLGT195 and Sawdust have said thanks
#28 TomLGT195 OFFLINE
TomLGT195
  • 3,833 Thanks
  • 2,816 posts
Posted January 22, 2015 - 04:49 PM
 Let's start with, great job! :rocker2:   Did you use a bead roller? If so, can you tell me what brand and maybe a pic? Thanks, Tom
#29 petrj6 OFFLINE
petrj6
  • 4,083 Thanks
  • 2,369 posts
Posted January 22, 2015 - 08:39 PM
   I used the press brake at work, cut a template out of a 3/16" plate to match the divot in the panel.  then placed it correctly between two flat plates and pressed it together to get the results.  I am actually pretty impressed with the result myself.
        Pete
  • TomLGT195 and VintageIronCollector have said thanks
#30 VintageIronCollector OFFLINE
  • 1,424 Thanks
  • 1,856 posts
Posted January 22, 2015 - 08:47 PM
        Pete
If you can make a panel you can make a hood!
