317 h2 hydraulic system in a 314
6 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted December 28, 2014 - 03:13 PM
I am insstalling h2 hyd from a 317 on my 314. Since I don't use mower deck any longer can I bypass or remove the lift cyl ?
Thanks for any help.
#2 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted December 28, 2014 - 03:26 PM
Yes you can  I would plum in a valve before the deck lift cylinder and shut off the flow instead of removing it.
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 28, 2014 - 04:41 PM
Larry, nice to hear from you!  You should leave it in there if you ever want to have a sleeve hitch on the 314. That cylinder lifts the hitch. The plumbing gets pretty convoluted in there on the 317. The drive shaft on a 317 is in a different position because of the higher crank shaft on the twin cylinder engine. That may effect the routing of the lines. It may be easier to get a rubber line or 2 made up then to try to fit it all in there using rigid lines.
  There are a few pictures of the line routing in my topic on the 317 refresh. Near the bottom of the page there are some pics of the bare frame with the valve installed. There may be some more pics later that might help you route the lines to the valve. It may be worth a look. http://gardentractor...?hl= needs tlc
  • MH81, Trav1s and larryd have said thanks
#4 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted December 28, 2014 - 06:37 PM
Thanks guys ,
I'm am going to lleave cylinder in tractor . But I think I might cap it off for now because it has 1 hose that leaks and needs to be replaaced Since I 'm trying to install the h2 set up the simpler the better. It doesn't look like the line hook up for hydro to the valve for the h2 is  the same  as the h1.
larryd
#5 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 04, 2015 - 06:27 PM
I need help again guys.
My control links from hyd control valve to control levers won't hook up becaause they hit frame. Any help would be helpful.
The set up is suppose to be from a 317 .
Thanks
larryd
#6 Trav1s ONLINE
Trav1s
  • 3,310 Thanks
  • 4,365 posts
Posted January 04, 2015 - 08:59 PM
Got any pics?
#7 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted January 15, 2015 - 07:45 AM
Travis, I finally got it working .
Thanks
larryd
  • Trav1s said thank you
