Pictures of pistion out of my Kohler 12hp
8 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,427 Thanks
  • 4,025 posts
Posted December 28, 2014 - 01:01 PM
Here are pictures of the piston out of the 12 hp Kohler that blew up this summer cutting grass, some of you may remember. I am going to put a new piston and rod in.  The bore looks good, but have not got a good look at it yet.  So, I figure that it wont need to be bored out, so no going to a 14hp from a 12hp. That was just a thought if it needed boring. Pictures not so good, but gives you the idea as to what happened.  So I will do some measuring and then start looking for parts.  Good to have a spare engine. Thanks for looking,   Noel
  • olcowhand, Alc, Texas Deere and Horse and 10 others have said thanks
#2 KennyP OFFLINE
  • 37,377 Thanks
  • 45,437 posts
Posted December 28, 2014 - 01:07 PM
I think this is what happened to my K341 in the Ford. Haven't pulled it yet to see though.
  • tinbender7 and propane1 have said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 28, 2014 - 01:48 PM
Split the top right off that piston... wow.
I'd check your bore carefully.  No way that it didn't get chewed up some.  I'd also check and make sure it isn't worn out of specs.  I've seen a piston split like that twice, one time due to overspeeding the engine and the other time due to the bore being worn oversize from use and the piston slapping around freely.
Check it carefully.
That's the old style piston, the newer styles were different.  They called the new ones "Mahle" pistons.
Ben W.
  • Alc, Texas Deere and Horse, KennyP and 4 others have said thanks
#4 Sawdust ONLINE
Sawdust
  • 5,561 Thanks
  • 3,335 posts
Posted December 28, 2014 - 04:14 PM
I agree with Ben I would have it bored. It's had to believe the cylinder isn't damaged.
  • superaben and propane1 have said thanks
#5 JDBrian OFFLINE
  • 9,601 Thanks
Posted December 28, 2014 - 04:47 PM
Looks like it should be repairable.  There should still be parts kits available on EBay for those motors Noel.  Genuine Kohler parts are pretty pricey if you can get them.
  • propane1 said thank you
#6 propane1 ONLINE
propane1
  • 8,427 Thanks
  • 4,025 posts
Posted December 30, 2014 - 06:45 PM
No damage to cylinder. Had better look at it tonite. And any measurement I do are good , but I am not an engine professional. New ring gap is .024 top to bottom and the same if turned 90 degrees. Bore measures 3.379 top to bottom and turned 90 degrees. Book says 3.375. Rod measures 1.501. Have not measured crank yet. Noel
Edited by propane1, December 30, 2014 - 06:54 PM.
  • Sawdust said thank you
#7 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted December 30, 2014 - 09:33 PM
.024" End gap on new rings does not sound right.
A common guideline is .003"-.004" gap per inch of cylinder.   .....So, 3.375 x .004" = .0135" End gap.  ...Yours is almost twice that amount.
What rings are you using?
  • Sawdust and propane1 have said thanks
#8 propane1 ONLINE
propane1
  • 8,427 Thanks
  • 4,025 posts
Posted December 31, 2014 - 05:54 AM
Book says new or bored engine. .010 to .020. Used engine .030 maximum. This is for ring gap, so I figured .024 was good. Ring is new and for standard bore engine. Noel.
Your answer should be 0.0135 I think, if I did it right. Noel.
Edited by propane1, December 31, 2014 - 06:20 AM.
#9 propane1 ONLINE
propane1
  • 8,427 Thanks
  • 4,025 posts
Posted January 20, 2015 - 09:46 PM
Going back together soon, have the parts now. Noel
  • olcowhand said thank you
